Jam_Master_J
- Aug 25, 2003
Does anyone know a good circuit I can build to adjust the phase of a subwoofers input signal. I'm building some subs but since I'm not using plate amps I don't have precise phase adjustment. Heres the setup:
Monica 2 DAC -> Cambridge Audio 540A -> Harris Varible low-pass(currently at 60Hz) -> Power amp -> Two DIY subs
Basically I'd like to use it between the LP and power amp and have adjustment from 0-180 degrees.
