Shure or bust
- Jul 24, 2015
I never heard the LCD-4 but heard the LCD-3 and had the LCD-XC which I both liked and found both pretty similar. Still, I preferred dynamic cans.
I had the Utopia for a weekend and compared it to the M1. I found them to have a rather comparable sound signature with the M1 being better in most areas. More bass extension and control, more highs extension without being bright (neither is the Utopia), more detail and wider and slightly deeper soundsatge and more engaging overall. Concerning the mids I find the M1 to have a full and detailed midrange with a hint of warmth but the Utopia was a little warmer which I like. Note that I find all these differences to be minimal, both are nice phones, the M1 just is a bit better IMO.
When it comes to comfort the M1 is very comfortable but the Utopia beats it there, never wore a more comfortable pair of headphones, it's like it was shaped to measure around my head. I do like something that feels a bit heavy and firm around my head though but the Utopia felt like it couldn't slide off no matter what you do without feeling heavy.
They're definitely Summit-Fi and somewhwere at the top of that class.
The utopia is a brick compared to the Sem1. I think of the sem1 as a better built hd800. The M1 is at the top of its class in the comfort department. Id rank my headphones: Sem1 > k812 > hd800 > hekv2. Anything over 400 grams is a no go for me 99.8% of the time. Since i listen usually 3 to 7 hours at a time. I removed the gimbal to improve lateral comfort, as well as easier on/off. I wanted to mod a sr009 headband on the sem1 for greater surface area. I also like the k812 breathable mesh suspension band. Ear cup wise, i didnt remove them due to glue. Didnt install mrspeakers electro stat pads.
