One channel of my Project Phono box SE II suddely stupped working, i opened it and found a pcb half the size of the whole enclosure stuffed with all smd components, nothing easily serviceable, so i decided to build something new and went for an Hagerman Bugle.
I tried to fit both the power supply and the amplifier board into the old Project enclosure ( which is of pretty high quality ) but it turned out to be a mess so i reached for a cheap plastic box i had at hand to fit the power supply. It will be located out of my sight so the looks don't matter much.
The amplifier board fit perfectly into the project box, no holes to drill, as the Phono Box already implemented the possibility to supply external dual DC power ( for battery operation i think ) via a din connector; not the best choiche, i think, but since it's a low current device, it should to its job. Decent quality Rean rca plugs fit in place of the old pcb mounted connectors.
Panasonic polypropylene caps are used for the filter section, and two wima MKS for supply decoupling, i didn't use costly resistors, just standard 1% tolerance metal film. I went for three LM4562, as i never tried them before but i've read good impressions here and there, and i have to say they sound pretty good; compared with the Phono Box SE i think i've seen quite an improvement in sound quality, even if the project was a decent design:16V AC wallwart feeding a voltage doubler and a pair of Lm337/317 regulators to provide full +/- 15V to some Jrc opamps implemented in a dual mono circuitry.
Compared to the TCC-750 i was using as a temporary replacement it's a huge step-up, the TC is rather good, but with its cheap switching power supply and crappy electrolytics in the signal path it can't do any better than the bugle even being a discrete design rather than opamp based, not that in general discrete circuitry is automatically supposed to sound better than well implemented opamps...
The enclosure looks pretty good doesn't it ? The brushed aluminum front plate is 3-4mm thick and the chassis is rather heavy and sturdy..
