Hey guys,
I'm running a 12V SLA battery system consisting of a DAC-AH and tripath amp. I'd like to wire up a power on/off switch just after the bulldog clips which connect to the battery's terminals.
Is it enough to use a SPST switch on the Positive (hot) cable? Or must I use a double switch that also cuts off the Negative cable too?
I'm conerned that getting this wrong may mean a safety hazard and constant drain on the battery.
Cheers.
Cheers.
