Ksweene5
- Jul 24, 2015
Hello HeadFi -
My issue is this -
Most of my listening (80% I'd say) is done at work, on a work computer, where I likely don't have the ability to install a driver for an external Amp/DAC. Almost all of this listening is via Spotify paid HQ streams. I had been planning on buying a portable Amp/DAC to maximize my use of the device, I also listen on via my phone (Android) to various high quality formats. I am sure some of my HQ albums are higher than 24/96.
My work computer is a Windows 7 laptop, so only Audio Class 1 will plug-and-play. I had the JDS Labs C5D near the top of my potential buys, and am leaning that way due to the fact that it's listed as a Audio Class 1 and will work plug-and-play. I am in the $300 or down (ish) rage to buy (iBasso Bushmaster, Oppo HA-2, maybe even up to a Ray Samuels).
My questions -
- Am I sacrificing minimal quality improvements to my work listening, at the expense of my listening to HQ audio I own?
- Would I be better off using just an amp at work, and then having a more versatile DAC? (Even if that is a combo and I'm bypassing the DAC in the office).
- What would I be giving up in terms of file compatibility? Am I going to have files that won't work with the C5D?
- Any other comments or rec's are appreciated.
TIA
My issue is this -
My questions -
TIA
