I've purchased the Vsonic GR06's in May 2012, since then I already had to use the warranty that came with it because of a driver issue.
Now after a year of use I've got the same problem again, the driver on the right side doesn't work when I insert it. Also when I tap it hard on the bottom of the housing the driver will stop working until I reinsert the 3.5mm jack into the connector. Then it'll work again but stop when I tap it or insert it again.
Is there anyone that can help me with this problem? Am I doing something wrong? Should I just save up for a more durable IEM? (I have the Etymotic ER-4's in my mind)
Please help me.
Please help me.
