teejmiller
- Feb 2, 2015
Morning! I've been lurking around the forum to determine if the older E9 works with the newer E07K
I've come across this post, but I believe it is translated and doesn't give a straight answer:
http://www.head-fi.org/t/641216/notification-about-the-compatibility-between-e09-e09k-and-e7-e07k-e17
So, I'd just like some confirmation from anyone who's tried and got the E9 to work with the E07K? I'm assuming the gain will have to be switched down and no aux connections from my research. Thanks!
