jack33001
Howdy everyone, first post here.
Finally, after six and a half years, my Shure SE215s have kicked the bucket. Now, I'm looking for a replacement in the $100-$150 range - I listen to a wide enough range of genres that I would like a fairly versatile IEM, which I will be running off of my iPhone. So, here are what my thoughts were on the SE215s:
Pros:
- Excellent isolation
- Super snug fit
- Good in the mids and lows - maybe just a little bit bass heavy, but I'm nitpicking here
- Replaceable cables
Cons:
- Lacking a little bit in the high end
- Mediocre soundstage
- I can't really put my finger on it, but they felt like they were missing *something*; like if you took 'veiled' to an extreme. Maybe I'm unhappy with their detail?
- The cables were kind of crap
And here are the must-have features in my next pair of iems:
- Good isolation
- Can be run from my iPhone (no amp)
- Maximum price of $150 new
So, given this info, what should I go for? Is there now a better fit for my needs than the SE215, or should I just get another pair? I should note, I think it would be fun to switch it up and try something new, but if you don't think there are better options for my needs, then by all means just recommend the SE215 again.
Pros:
- Super snug fit
Cons:
- Good isolation
