Fírnen
Weeks of reading around here and I am nowhere near a decision on what to buy. Prices vary wildly, spec sections are nonsensical to my inexperienced mind. Talk of DACs that add "color" with tubes and aftermarket parts. I do not really care about any of that yet; I just want "good" sound. I daily drive a set of Empyreans, and I have a FiiO M17 I run in DC mode as my DAC/AMP. Really like that sound but it would be great to have a better dedicated device at my computer.
The requirements: It needs to connect to my PC. Needs a 3.5mm jack at least, 2.5mm and 4.4mm appreciated. Needs to have a fast enough response time for games. No idle function, I should not hear sounds cut in late if there is a period of silence (Think typical computer usage). This should go without saying, but it should sound at least as good as the M17 with my Empyreans; expecting better though, since it should be a dedicated DAC/AMP for desktop use. A lower noise floor suitable for IEMs would also be greatly appreciated. Price not to exceed $2,000. Below is the list of what I may use besides the Empyreans.
What I currently own: Of my growing collection of audio gear, the Empyreans win with plenty of room to spare in terms of my perceived sound quality. Other HPs I have includes the Meze 99 Neos, the Kbear KS2 (IEM), Sennheiser HD660S, and in early october I should also have a pair of Unique 7Hz Timeless IEMs. Also plan on owning the Meze Lirics at some point. The only (reasonable sounding) sources I currently have are the aforementioned FiiO M17 and FiiO BTR5.
I would like to emphasize the desire for reasonable response times for the device. My M17 works well enough, but in day-to-day computer usage I despise the way audio cuts in after a second (it seems to have an idle function if there is no sound playing). For a device claiming to be able to function as a desktop DAC, that is unacceptable to me (I have not been able to find any setting to fix that, nor any mention of the issue online). I am OK searching for used deals if need be to stay under my price target, and I may do that regardless anyway. Also, while I expect to use line-in from my PC, USB DAC functionality would be nice to have. I have seen mixed opinions on whether DACs should add any color of their own at all; if clean, accurate sound reproduction can be had at a much cheaper price point, those suggestions are welcome. Also, if anybody knows a good brick-and-mortar hi-fi store I can visit in San Diego, that might be the best route to take if I can't decide based on suggestions here.
There is no need to throw technical terms around, as I will not fully grasp how they may or may not affect sound. Driving the Sennheiser HD660S to it's full potential is not really a concern either. I suspect I have not given it a fair shake with a powerful enough setup. This does not matter though, as I plan on getting rid of them at some point; as it stands I don't believe they can give me a sound I would like as compared to my Empyreans, 99 neos, or even the Kbear KS2's.
