bildar
does this plugin work with vox? I am not able to figure out how to set it up. what about tidal?
If you are asking about Vox for ac, you can use the Reveal AU plugin for Mac and Vox supports AU plugin (see here)does this plugin work with vox? I am not able to figure out how to set it up. what about tidal?
The Reveal plugin tries to keep the loudness level close to what it was before applying the plugin, but it is only a fixed gain adjustment and does not guarantee to prevent clipping. It is best to use a -3dB gain setting to avoid clipping for most music and a setting of -6dB for music with low DR.Quick question, when Reveal boosts certain parts of the signal to equalize the headphones, does it reduce the gain by itself to prevent peaking? Or do we have to do that manually by ourselves? Is there a way to set it to automatically move the gain knob down the correct amount to prevent clipping? Unless I'm using Reveal with Equalizer APO, I'm reducing the gain blind.
Thanks!
Since LCD2C was released only recently, the plugin has not been updated but we plan to update it soon with LCD2C presets. For now you can try LCD-2 preset. If you want to know what the LCD2C preset will sound like, we just made it available on Roon, you can test drive the trial version.Hello! I installed this on my Mac but I don't see an option for the LCD-2C .. only the LCD-2. Is that what I should be picking anyway?
Sorry for your issues with Foobar2k, I would be happy to help you.Has anyone ever got the Reveal plugin to work with AIMP music player? If so, how?
I tried with Foobar but the plugin keeps freezing. It stays on the screen but you can't change the settings for it after a while.
Thanks.
Are you looking for a preset for LCD-2C? We hope to release it in few weeks.Any better idea of when Reveal will be updated? I've never really felt Roon was anywhere near how much it cost and have already used a free trial previously.
