Quick question, is the VST version of the plugin 2.0 or 3.0?
Both VST 2.4 and 3, 32 and 64 bit
Good to know. Thanks!Both VST 2.4 and 3, 32 and 64 bit
What DAW are you using this with?I've tried for two days. Updates have been done, I have tried letting it choose settings for comparability and nothing. It should be said that I am computer duuuuuuuumb.
Can you provides some more information? Are you using Amazon Prime Music app on Windows/Mac?Closer but still too stupid to get this
Looks like MusicBee supports only winamp plugin, Audeze Reveal supports VST on Windows. You could still use Musicbee but install Eualizer APO and add the reveal plugin. Instructions are here.What is the plugin like with the LCD2-C im intrested in giving this a try and does it work with MusicBee, I do have the Audeze Revealusb that came with the cans
Hi KMann thank you for reply how do i install Eualizer APO please id like to install it and use Reveal with MusicBee for Windows 7. Do i Add reveal to the Eualizer APO file and then Add the Eualizer APO to MusicBee? Many thanksLooks like MusicBee supports only winamp plugin, Audeze Reveal supports VST on Windows. You could still use Musicbee but install Eualizer APO and add the reveal plugin. Instructions are here.
If you have at least 2 Audeze models at the moment, my question is for you:
Do you think the plugin similarizes the sound of different Audezes? For example, is the darker sound you get with the LCD-XC making it similar to LCD-3 and vice versa?
