i never had this issue at all so far.....maybe you're pc ?!@pollyjingjing , I reported an issue with windows driver the other day, which is sometimes it plays only static noise,
And I had to restart foobar and kill driver daemon to get it to work, any clue about the issue?
Sabaj D5: the DAC that is unquestionably a digital to analog converter
- Thread starter DaaDaa
gto88
- Dec 11, 2014
Thought of that, but other dac are fine all the time.i never had this issue at all so far.....maybe you're pc ?!
I will uninstall other drivers, and see if it happens again.
btw on win 10 you don't need drivers, the unit works fine without, how is this on you're pc ?Thought of that, but other dac are fine all the time.
gto88
- Dec 11, 2014
correct, only if you want to play DSD512.btw on win 10 you don't need drivers, the unit works fine without, how is this on you're pc ?
and are u in DSD ?correct, only if you want to play DSD512.
gto88
- Dec 11, 2014
Yes, I have many dsd collection, dsd512 is for testing dac/driver.and are u in DSD ?
i think DSD is uselessYes, I have many dsd collection, dsd512 is for testing dac/driver.
gto88
- Dec 11, 2014
DSD or PCM, it is subjective, many claim converting PCM to DSD512 makes it better.
I couldn't tell the difference though.
me neitherDSD or PCM, it is subjective, many claim converting PCM to DSD512 makes it better.
pollyjingjing
Member of the Trade: SABAJ
We have tested here, didn't find any problem and didn't have the noise, maybe something wrong with your PC. Try to antivirus or download foobar again.@pollyjingjing , I reported an issue with windows driver the other day, which is sometimes it plays only static noise,
pollyjingjing
It needs an upgrade tool to upgrade to the new firmware. Where you bought it and I will send you the tool.I love my D5 but turning the volume wheel does nothing,
gto88
- Dec 11, 2014
Ok, Thanks for following up, it didn't always happen, so far so good in last few days.We have tested here, didn't find any problem and didn't have the noise, maybe something wrong with your PC. Try to antivirus or download foobar again.
I will watch how it happen if it happens again.
The newest is 1.4, or there is newer?It needs an upgrade tool to upgrade to the new firmware. Where you bought it and I will send you the tool.
And the upgrade tool is a software?
pollyjingjing
That is not software, it is a repair tool, if you have the volume knob problem need to update. If not doesn't need.Ok, Thanks for following up, it didn't always happen, so far so good in last few days.
CageyH
- Jan 29, 2009
I am interested in buying a D5 from Amazon.fr, but is the firmware on these units V1.2 or V1.4.
