Schiit Mjolnir 2 Listening Impressions
jonathan c
Is it fairly easy to take off the cover? Are any special tools needed? I ask because I want to install (remove) Tubemonger adapters without damage / wear n’ tear.
ksorota
Do you need to take it apart to fit an adapter? I normally just attached them to the tube and slot them all in in one go.Is it fairly easy to take off the cover? Are any special tools needed? I ask because I want to install (remove) Tubemonger adapters without damage / wear n’ tear.
Seperatly I contacted TubeMonger about the CV4033 and adapters. They referred me to the manufacturer:
https://pulsetubestore.com/products...-plug-play-ready-to-use-m-pairs-quads-singles
https://pulsetubestore.com/products...uction-base-9-pin-b9a-noval-not-made-in-china
Guidostrunk
Now that's interesting. It's literally the same font and listing as tubemonger. Makes me wonder if it's their store.Do you need to take it apart to fit an adapter? I normally just attached them to the tube and slot them all in in one go.
https://pulsetubestore.com/products/12axx-to-ecc88-adapter-plug-play-novib-©-1960s-nos-british-mcmurdo-phenolic-socket-on-top-plus-vibration-reduction-base-9-pin-b9a-noval-not-made-in-china
Regardless, people have access to both now lol
I think they are independent of each other but Pulse Tube Store supply custom made adapters and tubes for TubeMonger.
The person I spoke to at TubeMonger said the people at Pulse Tube Store are in India so wouldn't reply to any messages until tomorrow due to the time difference.
ksorota
You do not have to take it apart to put the adapters in, but removing the adapter is a bit difficult with the top on. Its very easy to get the adapter off when the top is off though!
Ah that makes sense. Thankfully I have never had a problem removing them before.You do not have to take it apart to put the adapters in, but removing the adapter is a bit difficult with the top on. Its very easy to get the adapter off when the top is off though!
You lot are a terrible influence, just ordered a set of Brimar CV4033 for my Mjolnir 2. @Ripper2860 would be so proud
Guidostrunk
Did you get the adapters?Ah that makes sense. Thankfully I have never had a problem removing them before.
Yep, I would have been pissed if the tubes arrived and I couldn't use them!Did you get the adapters?
Guidostrunk
Definitely post your thoughts after you spend some time with them. Don't judge them out of the box. They take a bit to open up to their full potential.Yep, I would have been pissed if the tubes arrived and I couldn't use them!
jonathan c
Thank you. It was the removal, should it occur, of the adapters that I was concerned about.You do not have to take it apart to put the adapters in, but removing the adapter is a bit difficult with the top on. Its very easy to get the adapter off when the top is off though!
jonathan c
I just put in an order for extra 12Axx to ECC88 adapters with Pulse Tube Store via their website. No “out of stock” indication, payment via PayPal.
Guidostrunk
You happen to grab a pair of cv4033?I just put in an order for extra 12Axx to ECC88 adapters with Pulse Tube Store via their website. No “out of stock” indication, payment via PayPal.
Guidostrunk
I also have an extra pair of 7728 i can send your way for evaluation when you get your MJ2 back if you'd like. Shoot me a pmYou happen to grab a pair of cv4033?
Total: 7 (members: 0, guests: 7)
