Ince
- Jun 21, 2010
My IE300 right side finally failed on me after months of loose connection. The connection does not connect correctly and goes off just slight movement. I ordered a new cable as thought it might be the cable but the connection was worse and the connection was loose. The Left side works fine and even connects and works perfectly on 3rd party cable.
I do not think will buy Sennheiser IEM again unless they fix the issue with the MMCX connector issue or go back to 2 pin which was fine.
