I tried about eight more different types of tips today, courtesy of MRS dropping some off for loan. Quick context: I love how the IE900 sounds with the stock silicone smalls, but they don't seal reliably. The stock silicone mediums seal for me, but they sound noticeably worse.
Acoustune AET07 (S): These add on about 1dB more sub-bass presence. They're noticeably looser than the stock silicone smalls in terms of bass control, and they don't give me the same depth of slam. The AET07 also shave off some mid-treble sparkle which might be helpful for listeners who felt the IE900 was peaky. Transients generally sound slightly dull with the AET07. This is a pretty pleasant adjustment to the IE900's sound overall, but not what I'm looking for.
Acoustune AET07 (M): These detract about 1dB from most of the frequency spectrum, up until the treble, where the lower-treble sounds the same as with size Small AET07, but the mid-treble is dampened some more. Sounds overly dull with this tip and fairly dark. Not a fan.
Sedna Earfit Light (MS): These bring up the lower-treble from stock silicone small and emphasize the mid-treble aggressively. Sounds fatiguing. Transients sound dull with this tip and somewhat coarse. Not a fan.
Sedna Earfit Light Short (MS): Same coarseness to transients going on as the Earfit Light, just not to the same degree. I can tolerate this. I do feel that this tip mimics the stock silicone small tips more closely in terms of treble response than the others above, but it's not quite the same. Still not getting the bass response I want from these tips. The bass sounds somewhat loose and they're shaving off a decibel or so of sub-bass. "Ehhh" overall.
Sedna Earfit Short (MS): Similar bass response to the other Sedna tips above. Just doesn't sound as organic as it should and doesn't sink as deep as the stock silicone smalls. Treble on this tip is brighter, more closely reminiscent of the Sedna Earfit Light which I didn't like. This tip isn't it.
Ostry 0S100/0S200/0S300 (S): Wanted to play around with these because they have filters. Nope. Sound horrible with the IE900. They all screw up the upper-midrange and the treble, and none of them seems to have any air. Definitely not the tips to pair with the IE900.
Add these to every SpinFit tip, Azla Xelastec, stock foams, L2 stock tips, and MEST MK2 stock tips not working.
I have some small Sedna Earfit tips on the way, and I'll probably need to pick up some spare stock silicones at this rate because I keep taking them off lol. It's incredibly vexing that an IEM is this sensitive to tips; to be perfectly frank, I think this is just poor design of the stock silicone tips. Nonetheless, the hunt for a replacement tip continues!
