Has anyone else seen an issue with the player just randomly shutting itself down while playing a song? No changes with anything, it's a brand new MicroSD card, and it just started doing this today. When I turn it back on and start playing the same song or a different song it will just stop after a little bit and look like it is shutting down like I held in the button, and it is just sitting on a table. This is with wired playback using the balanced adapter. I'm going to try it with both wired unbalanced and Bluetooth to see if it does the same thing. M0 Pro was just fully charged, so there should not be an issue with battery charge.
<<Update>> Same thing with my IEMs that worked perfectly before, still shutting down after approximately 1m. I checked and auto-shutdown was not checked, although auto-standby is. Only seems to happen when the screen is off. Tried factory resetting it which seems to have fixed the problem for now.
@Shanling I’m not sure if anyone else has experienced this, but maybe it’s something to check in firmware since it seemed to be set to auto shutdown without showing it was set that way or me selecting it.
