Shanling M0 Pro - Ultra-Portable Hi-Fi Player, Now With Balanced Output!
Mar 10, 2024 at 9:34 PM Post #752 of 788
Hello Shanling team, hope you can make it work on 2tb sd cards on next update. thanks
Hello, please what issue are you facing with 2TB MicroSD cards? And which exact card are you using?
I wasn't aware of any of them available yet. With Kioxia and AGI cards announced, but not yet released on the market.
Mar 11, 2024 at 12:05 AM Post #753 of 788
I am using currently 1.5tb Sandisk card. and unable to be read despite file format fat32 and exfat. my 1tb runs file fat32 and exfat
Mar 11, 2024 at 1:41 AM Post #754 of 788
We have feedback on T1.5 Sandisk card, while in some extreme cases it can lead to a bit slower load time, they should still work.
Please what exact issue are you facing with the card?
And to be sure, are you 100% certain your card is not fake?
Mar 11, 2024 at 5:30 PM Post #755 of 788
yes i am sure it is not fake, i verified and also ordered it on sandisk official. exact issue, the card can't be detected (fat32, exfat)
Mar 11, 2024 at 9:06 PM Post #756 of 788
Are you on firmware V1.5?
So when you insert it into the device, it doesn't see it at all, correct?
Will report it to software team to check on it.
Mar 24, 2024 at 9:13 AM Post #758 of 788
Hello, I've dug up my old M0 and see that when I import playlists, the playlists are listed in random order, making it hard to find specific playlists. I'm wondering if this is also the case on the M0 Pro? Thank you!
Edit: I also see that my favourites are listed in alphabetical order rather than in the order I added them. Does this happen on the M0 Pro too?
Mar 24, 2024 at 9:07 PM Post #759 of 788
Yes, it's the same behaviour.
Mar 28, 2024 at 5:27 AM Post #762 of 788
Can the M0 pro receive signal via BT and output it via USB ?
Yes. Just make sure you have USB DAC connected and all settings done before connecting Bluetooth to M0 pro.
Apr 1, 2024 at 7:54 PM Post #764 of 788
Apr 4, 2024 at 10:45 AM Post #765 of 788
Just leaving my suggestions for a future firmware update, some nice to haves that I hope someone thinks would also be useful.
1. Ability to choose the source of the lyrics, lrc or embed (maybe an option in the settings to alternate the configuration);
2. Don't list the artists with the name starting with "The" in "T", e.g.: list "The Doors" in the letter "D", or "The Cure" in the letter "C";
3. The menu Genre would be nice to be like: "Genre" > "Artist" > "Album" > "Tracks" instead of "Genre" > "All Tracks";
4. Ability to adjust the speed of the scroll;
Thank you!
  • Back
