yoo-hoo
- Jun 3, 2014
Hi ,
I have a Shure SRH440 with the stock coiled cable , wanted to know if someone has tried any of the following cables on the headphones and if they worked ?
- AKG K451 or K452 cable
- Pioneer HDJ 500T cable
what i m looking for is to have a shorter cable that has an inline microphone . still with the 3.5mm - 2.5mm plugs , 6mm in diameter on the 2.5mm side to fit in the headphone jack opening .
thanks ..
thanks ..
