Slow VS Fast roll off and Minimum VS Linear phase
Jun 25, 2017 at 3:16 PM Post #46 of 61
As far as I am concerned, it is hard to figure out how stereo image can be affected regardeless of filter type linear/minimum phase used in DACs.
Especially when assuming that:
  • stereo has been properly implemented before reaching DAC level,
  • Left @ Right Channels are receiving same symetrical digital and analog treatment inside DACs
Do you mind elaborating more, please?
I am more prone to rather suspect DACs` digital signal processing for such behavior....
Yes exactly, the minimum phase filters are usually done over DSP but some like the Schiit Fulla and Jotunheim DAC portions use analog filtering. These are cause the destruction of stereo width and imaging with minimum phase filters. Of course it is applied to both channels, I don't know why that was brought up at all earlier in the thread.
Anyways on a DAC with switchable filters, is easy to hear what the minimum phase filter does (collapse stereo width/imaging on recordings), why it does it (not time-domain coherent), and how it does it (some frequencies are delayed more than others going through the filter). If you have a decently resolving, high-fidelity system and not closed headphones, bookshelf speakers on a bookshelf, or one of those bluetooth amazon/apple pod egg things, it is pretty easy to hear with a DAC that has switchable filters.
As for the psychoacoustics behind it I don't know. Family Feud style internet sampling done by Archimago? I don't care.
Jun 25, 2017 at 7:27 PM Post #47 of 61
I think it's repetition of snake oil sales pitch used by some DAC manufacturer to make potential customers worry about aspects that no human can actually hear.
I'm not ready to say that humans couldn't hear a difference between a linear phase and minimum phase filter at all, given just the right circumstances. Pretty sure you could show some degree of audibility. But I'm not sure it matters, though, since you're only changing one known filter in a long chain of filters of various phase responses. What you actually hear is a composite filter made up of many cascaded filters, with a composite response. There's no switching a DAC filter to change that, there's already way to much done in the entire chain that you don't know enough about to respond to.
It's also a well known fact that if you put a switch on a bit of audiophile kit and label it with anything that indicates a change in perception, it will produce an audible change (even if the switch is never actually wired to anything). I actually did this decades ago with a knob in a studio ambiguously labeled "correlation", with 0-10 scaling, and the instructions that it should be optimized for each individual bit of audio being transferred. And it was adjusted, very carefully, and made an audible difference. I never soldered a wire to the pot.
Jun 26, 2017 at 10:45 AM Post #48 of 61
The analog filtering is probably in place for reconstruction - that is, to filter out the images centered around multiples of the oversampling frequency and to account for the sample and hold output of the converter. The digital oversampling (low pass) filter is contained in the DAC chip itself, in this case the AKM 4490, and is where you can select from different impulse / frequency responses.
Personally, I don't think that a minimum phase filter collapses the soundstage, nor does it affect image stability / localization. For example, I thought the Meridian Explorer2 (minimum phase filter) sounded more expansive than the AudioQuest DragonFly v1.2 (linear phase filter). I also haven't noticed the soundstage for music played back on my Oppo BDP-103 to have greater depth or width than my Ayre C-5xeMP. Nor do I have a hard time locating performers within a space on either.
Archimago mentioned that the Pono's filter as designed by Ayre "does not show significant group delay in the higher frequencies" and consequently "phase shift through the audible spectrum is not an issue."
Charles Hansen also stated the following in an AudioStream interview:
"On the other hand, a minimum-phase filter has the same total amount of ringing, but it is all moved until after the impulse. This type of filter does have some phase shift, but it is very small and only at very high frequencies"
Finally, does this even really matter? There's phase shift in headphones too - look at the impedance / phase plot for the HD 650. Guess which transducers have a fairly flat phase response (at least until the upper frequencies)? Planars. Ethan Winer has noted that phase shift seems to have an effect if it's constantly changing and only if you combine a phase shifted signal with the original signal.
Jun 26, 2017 at 11:12 AM Post #49 of 61
as I said in a previous post, my own tests(actual tests recording stuff and abx) resulted in me being able to notice different filters only within my hearing range.
but there is another important aspect at play here. usually going with some filter decisions will go a different roll off speed. in short a different EQ in the upper trebles. and in some cases the roll off can start as soon 12khz. it's super small of course, but it means we end with both EQ and different phase filter within the audible range. and both have the ability to alter the perceived "image", so the only question is with each implementation, does it reach enough amplitude before it's out of the audible frequency of the listener? from my perspective a proper band limiting should of course be outside, but it doesn't mean all designs are. even more so when you decide to implement filter switch on your system. then of course the more audible it is the better.
May 3, 2018 at 12:55 PM Post #50 of 61
You made a claim that one should choose DAPs/DACs with right filter so I asked you which ones because you suggested me yourself to find the right ones.
Quoting every line I wrote like this is ridiculous. You're way too paranoid. Maybe you should do something with your audio obsession. Seek help.
Right on man , I dont have my PHD in DAC'S yet and was wondering the same thing, I wish he would just chill out and if he doesnt have an answer, dont reply at all. Instead we get 25 paragraphs of his rhetoric
May 3, 2018 at 3:31 PM Post #52 of 61
Square waves come out of my speakers when I play Lawrence Welk records!
May 5, 2018 at 2:38 AM Post #53 of 61
8QUOTE="Psalmanazar, post: 13564329, member: 433497"]That is the dow
nside of minimum phase filters; the change in arrival time of different frequencies is not uniform and greatly affects the perceived stereo image. Yes DACs with minimum phase filters will apply it to both channels and yes it collapses the stage almost always when compared to the linear phase one in the same DAC. There does not need to be a difference between channels, the stereo image is already messed with. Try ABing it yourself on something with switchable filters and you can hear instruments in a multitrack recording no longer be as well delineated and will usually move closer to the center. NOS DACs tend to be much much worse things than ones with minimum phase filters though.
There are some youtube videos that show the benefits of minimum phase filters applied to single instrumental tracks in mixing but they are not good for stereo recording or listening overall. The one benefit for consumers is that they can tame overly forward/bright DACs like ESS Sabre 9018 or poorly implemented Wolfsons. They are also good for brighter headphones like the stock HD 800 or Beyerdynamics. Yes it's not very high-fidelity to mangle the phase but it can result in more pleasing sound. Best thing to do though is simply not use super bright gear like that you have to work around the flaws like that though.[/QUOTE]
Old but good thread. Thank you for the elucidation on filters.
I assume proper source music, say a 2 miked recording is a given to even notice a differance.
How can "some member's" muli miked sources even convey a stereo image that is not marred to start with?
Thanks to @WindowsX for asking.
Much flak & bigotry is here too. ..
I guy ask a good Q! But let it be a stupiid one, (the one being stupid is the reciever btw) ,
He finally gets a good answer. & look at the trolls along the way. ....efing trolls
May 6, 2018 at 1:21 PM Post #54 of 61
Apparently it is a good answer if it fits your preconceptions and a bad answer otherwise (even if it comes from a manufacturer representative of not one but two DAP manufacturers)
https://www.head-fi.org/threads/slo...minimum-vs-linear-phase.836621/#post-13273121
Feb 2, 2021 at 12:33 PM Post #55 of 61
Few days ago I realized, that Super Slow Roll-off filter or NOS I quess on my AKM4493EQ suits best to my listening requirements. I'd always had difficulties with strangely bright treble and this filter makes it right, neutral. Bonus is cleaner soundstage. Can it be connected with no Pre and no Post echo?
Feb 2, 2021 at 2:54 PM Post #56 of 61
It sounds like you have a preference for a rolled off response curve. Your impression of soundstage is probably just your preference for less pronounced upper frequencies. There's no reason to expect an audible difference in soundstage.
Feb 10, 2021 at 3:03 AM Post #57 of 61
Now I am convinced it is Post Echo, what causes my difficulties with trebles. I'm sensitive to deviations at high frequencies and it was also reason, why I liked sound from soundcard or mobilephones more than DAPs. But NOS filter solved this and I'm happy now :)
Feb 10, 2021 at 4:09 AM Post #58 of 61
Why do you think it's post echo and not just a sensitivity to high frequencies?
Feb 10, 2021 at 4:55 AM Post #59 of 61
It is a sort of artificial gloss what I hear with all filters except NOS. I don't mind elevated high frequencies, but unnatural. Is it true that NOS has the best range in high frequencies?
Feb 10, 2021 at 4:57 AM Post #60 of 61
Pre- over sampling DACs have a steep high end roll off. My guess is your headphones have a spike in the upper range and the roll off tames it.
