So both my headphones sound tons better out of my soundcard.
May 3, 2011 at 11:44 PM Thread Starter Post #1 of 11
yepimonfire
the biggest improvement is in the bass, there isnt "more" bass, just better sounding bass. it definitely does sound different, i have no idea why either. any ideas? both my AD700s and HF5s sound way different out of it versus my ipod. it sounds more "focused" then the ipod in the other frequencies, just more musical all around. the HF5s show the most difference vs the ad700s in sound improvement.
May 3, 2011 at 11:50 PM Post #3 of 11
nano 3rd gen
realtek onboard, not a bad soundcard at all though.
May 4, 2011 at 3:08 AM Post #5 of 11
well my soundcard can provide about double the power of my ipod, 25% volume on the etys is reference loud for me, about 50% on the AD700s, with the ipod, the etys use 50-60% and the ad700s use a minimum of 75%. i do know that an ipod goes into clipping at about 85% volume, so im using a pretty good amount of power on the headphones.
Might just be that it's providing more power to the headphones.
May 4, 2011 at 10:31 AM Post #6 of 11
well to answer your question, it could be that your computer is supplying the headphones with a little more power. Remember, your computer is being plugged into an outlet vs the ipod which is running off battery. Soundwise, it's hard to believe that the realtek outperforms the ipod because in my setup, the opposite is true. But that's the answer to your question, direct source of power vs battery powered. If you're looking to balance things off with your ipod, just get a E7/E9 and attach it with your ipod. Many head-fi'ers seem to be doing that combo. For me, i connect my Cowon iAudio 9 with an arrow amp that power my sennheiser ie8s. Pretty awesome sound, and i'm happy with what i got
May 4, 2011 at 12:19 PM Post #7 of 11
I don't really like the realtek onboard sound cards I've used.  I've used two computers with it, and both of them have this awful buzzing/hissing noise in the background all the time, that alternates between channels and gets worse and sometimes all but disappears.  Kind of annoying.
May 6, 2011 at 7:04 AM Post #9 of 11
Realtek onboard? What? There's no way it sounds better than an ipod. Realtek makes some of the worst soundcards I've ever heard and bass is NOT the strong point of them.
May 6, 2011 at 8:49 AM Post #10 of 11
i think i figured out what it was, i have the soundcard set to upsample to 192k, when i set it back at 44.1, it sounds the same as the ipod. (minus the SNR, which is pretty bad)
