andrewski
- Oct 17, 2015
I have been repeatedly charging and discharging my battery. Rookie mistake
And battery care has made it more frequent.
I guess you should avoid discharging below 20%. Keep at 35-85% for best battery care.I have been repeatedly charging and discharging my battery. Rookie mistake
The Sony statement about "charging and discharging frequently" is meaningless, as that is what will happen if you use the DAP. It is just a generic statement, so do not read too much into it.I guess you should avoid discharging below 20%. Keep at 35-85% for best battery care.
Sorry for the late reply, thankfully SonyWalkmanuser has reply to you. Busy with new project lately, working around the clock, hardly enough sleep, lolHi there. I have a question. I'm looking at importing to the UK the grey version from Japan which I believe is the only uncapped region? Is there an easy way to change the language of the player from Japanese to English?
I have only tried the language setting with ZM2, the soundstage of Japanese is lovely, especially the height, but the vocal sound saturated, I end up sticking back to English.This is interesting. Looks like there is more mystery to uncover about this Sony chameleon sound signatures.
I wonder if this language setting would also affect the A306.
Maybe @FreeTime can share his experience?
Good info. Generally I loose 30% of battery at max after using it for 5-6 hrs or so and then I charge.The Sony statement about "charging and discharging frequently" is meaningless, as that is what will happen if you use the DAP. It is just a generic statement, so do not read too much into it.
An analogy is to say that if you eat a lot, you will go to the washroom more frequently. That is true, but so what? It is normal.
OPTIMUM BATTERY LEVEL TO CHARGE AT:
My recommendation is to charge from 50 - 60 %
The reason is due to the charging algorithm, which uses high current for a low battery level, reducing the current as the battery level increases.
- Low battery level will charge at high current. 20% battery level will charge at max current, say 2+ Amps
- Moderate battery level will charge at lower current . 60% battery level will charge at 1.2-1.5 Amps
- High battery level will charge at low current, tapering off to trickle charge. 70-80% will charge at .5 to 1 Amps
(current levels are approximate, just to give an idea of how the charger varies the current, depending on the charge level of the battery being charged. The actual current levels will be higher or lower, depending on the DAP/Charge circuit. The thing to note is that modern chargers are not constant current, but are variable current. And Lithium batteries do not like high current/heat.)
So the lower the battery level before you start charging, the higher the current. The higher the current, the greater the heat, and stress on the battery.
OPTIMUM: Charging at around 50% battery level will reduce the charge current, so less heat and stress on the battery.
NOT OPTIMUM: Discharging the DAP to very low levels before charging, as that results in high current and high heat for the battery.
Also pay attention to the heat dissipation of the DAP.
BAD PRACTICE for the DAP:
- blocking air circulation
- putting it on a pad, or cloth, as that insulates, and blocks heat transfer
- an insulating case will block heat transfer from the case, and retain heat in the DAP, and cook it. Fortunately, the Sony S-Master runs cool, so heat buildup is not a major problem for Sony DAPs
The above is my understanding.
Just a good rule of thumb, charging lithium battery up to 100 percent is not great as that does stress the battery the most. It's better to go down to let's say 30 and charge up to 80 percent. This regime is the fastest to charge and will minimize cycle damage.Good info. Generally I loose 30% of battery at max after using it for 5-6 hrs or so and then I charge.
I have that Battery Saver ON so it charges till 88% and then stops. I guess it should help battery in long run .Just a good rule of thumb, charging lithium battery up to 100 percent is not great as that does stress the battery the most. It's better to go down to let's say 30 and charge up to 80 percent. This regime is the fastest to charge and will minimize cycle damage.
Some of the other Chinese DAP like DX240 or DX320 do come with dual batteries, one for digital section and one for analog amplification section. Although this may result in better sound quality by isolating power supply noise, this makes maintaining proper charge level parity between the two battery extremely difficult as each section has different power load demands that is highly varied depending on user settings(DSP) and volume levels(amp load). In the long run I would think this approach would likely result in constant uneven battery charge levels between the two different battery cells, which ultimately results in faster battery deterioration in one of the batteries, leading to lowered reliability.The Sony statement about "charging and discharging frequently" is meaningless, as that is what will happen if you use the DAP. It is just a generic statement, so do not read too much into it.
I only use mine when I'm using my 1AM2 with an amp.I got this adapter fro Ddhifi for Walkman but I feel it takes away some Sony magic here. Sound is more open and light on its feet. Many enjoy such sound but I like heaviness and dense tonality of Sony. The decay of bass I feel is truncated. Will try for few more songs. So far only in my 3rd song with this adapter.
Aesthetically it matches the color of Walkman very well tbh. Does add additional 32gm though. May help in strengthening my grip further.
