I was working on a significantly longer post, but the "save draft" feature on this site is only valid for a day or two and then the draft gets deleted, so I can't be bothered to write everything again...
Via an iPhone
OMG don't do this! It sounds like if you're listening to music through a wet sock. Absolutely horrible.
VS Fostex TH-X00 Ebony
Well, the significant price difference really shows here. Sony does everything better and Fostex just feels boomy.
VS Dan Clark Ether 2
Role reversal from the above. Dan Clark does everything better than the Sony. Only thing Sony has going for it is the quantity of bass (which is why I bought them).
With EQ to remove the 3k and 10k peaks
So I did this after about a month of owning the headphones and holy crap, it's as if I got a new pair of headphones again (also pumped the bass up, which again is why I bought them).
Brain burn in is definitely a thing though, because the mids were extremely muffled when I first brought the Sonys home (no memory of it while auditioning in the store, weirdly though, because otherwise I wouldn't have bought them). Now, even though I'm swapping between the Ethers and Sonys, I'm not bothered at all by which initially was an extremely poor first impression.
EDIT: After upgrading to a much more powerful amp
Yeah, ok, the mids are recessed again, and the Ether 2 almost caught up in bass performance. It's still an interesting headphone for electronic music but for everything else, not so much. Next up will be a copper cable upgrade and I'll probably make an edit again after I receive those.
Oh, and very surprised at how much sound the Sonys let in (almost as much as the open Ether 2), while almost not letting any out (again good, because I bought them for office use).
(One thing I almost forgot... the headband material is quite disgusting. Very mushy and almost tacky to the touch. I remember at the store, it was the only headband which was utterly destroyed too... doesn't bode well. It's also still not very comfortable even after a month and change.)
Via an iPhone
