IkuMiku96
- Jan 8, 2017
My Superlux HMD-660e just arrived today now actually wearing it.
Bought from a direct supplier (Malaysia branch) that sourced directly from Superlux for around USD 12 (80% discount right now so i bought it)
I suppose the HMD-660 is literally Superlux HD 660 with a dynamic mic.
I owned Superlux HD681 (with velour pad and tissue filter mod, no razor blade sound) to compare with this.
I will post a review in Head-Fi later after a few days but these are my first impression of the headset.
Looks like Sennheiser DT770 with a mic lol~
I suppose this uses 150Ohm (same as HD 660) but weird, because this headset seems louder than my HD681. was a bit frustrating to play with my Sony Xperia A2 (or Z1 Compact) that the volume was a bit low with HD681 but HMD660e seems fine (still at 100% though).
I dont have any amplifier except my Home theater with 1/4" headphone jack (havent test with it yet) so the sound may be better with amp. but i can say that using my pc in board headphone jack sounds less harsh than using my phone.
(will try my Galaxy SIII with Boeffla kernel mode, cuz, that can run heavy headphone apparently)
[update]Tried my home theater amp via 1/4" jack, although the volume is the same, the sounds quality seems improve a lot. more detail and better bass response
[mic impression is after the sound impression, just scroll down to skip]
Basically, this is more 'boring' than my HD681. the sound signature is less dynamic than my HD681.
The bass response, is rather weak compared to HD681. but the body is still there (less punchy) and clean indeed.
Somehow, is rather a little bit bright than my HD681 but i did tissue mod to my HD681 so based on the HD 660 review, would be less bright than HD681 unmodified.
Mid is a bit better than my HD681 but a tad harsh in upper mid, maybe due to being bright?
Soundstage, not comparable to my HD681 but pretty good. Sound imaging is good (or even better than my HD681?). But this is closed can compared to my HD681 so i guess is naturally like that?
Comfort wise, truthly, is less comfort than my HD681, i do still remember how strong my HD681 clamping force was but this is even tighter. The pad's skin is soft, like the Sony pads (similar to Sony MDR-7509) but the sponge inside the pad is rather stiff.
Build quality, i would say, feels cheaper than my HD681. But the metal hinge on this headphone seems robust and looks nice with the aluminium brush. (just noticed the label strip on the right earcup is loose
Mic impression,
I MUST use 30dB and at 100% mic level. if i dont use mic boost, my friend cant even hear me. i guess this need a power amp or Phantom power. the 660x ver uses XLR connector which may need Phantom power i bet the mic is the same with 660e so yeah, still need power. but surprisingly with all mic boost, the sound quality is above average.
less sibilance and rather balance overall. i will try music recording later (despite of a headset mic) for quality comparison.
the foam attached to the mic seems tight and i bet the foam will tear off if i try to remove it. weird.
i do noticed that Superlux HMD660e has very few review so i posted this for a quick impression of this heatset.
i dont really know if the HMD660's sound quality is similar to HD660 i did read one of a blog said that the sound is pretty similar so i take that word.
(if you need pictures, let me know~)
(and hey, if you own this and possibly HD660 too, please share your experience~)
Mic impression,
