A man coincidentally learnt about the mod through their website today. I've not gone about researching about it though. Never knew a Tsuranagi mod existed.Has anyone tried the NPAudio mod for the Tsuranagi?
The Brise Audio Japan Cable Thread
- Thread starter AnakChan
Hey guys,
I bought an Asuha LE yesterday, and was wondering if it's okay I just bend the cable hard around the ear to make it conform? The end came super straight out of the package (as Brise cables do).
HiFiDJ
- Dec 26, 2013
Since impressions are so sparse for their headphone cable line, I wrote a little article on it myself. Feel free to share it...
https://www.sonusapparatus.com/2024/01/brise-audio-headphone-cables-japans-finest/
findthereal4
Have brise audio started to take orders for murakumo 2 yet?
I've ordered Murakumo 2 USB Cable...but have to wait for months.
HiFiDJ
- Dec 26, 2013
What connections are they making it available for? Is it only digital for now?Have brise audio started to take orders for murakumo 2 yet?
bukumurah
Hi Fellas, I was wondering if anyone can give me an insight on cable requirements for the tsuranagi..
I understand that both the DAP and the interconnects must have the grounding (5th pole) enabled/connected if using 4.4mm connection..
How about the iems cable though.. how are we supposed to connect the ground pin on the 4.4mm pentaconn plug to the 2-pin/mmcx connectors?
Or can I just use any standard 4.4mm iems cable without any grounding? While I save up for some Brise Audio's cables..
Thanks so much in advance ))
There are some notations that do not match. For an IC, the signal level is small, so EMI could affect the subsequent chain by being amplified along with the signal at the amplifier. The IC should be shielded, and when it is shielded, the shield needs to be grounded by connecting it to one side (GND pole), so the energy generated by EMI will be flushed out to the ground on one side. If you connect both sides, it might have unidentified effects, but it is better to connect only one side.Hi Fellas, I was wondering if anyone can give me an insight on cable requirements for the tsuranagi..
kajetanjazz
Has anyone tried pairing Tsuranagi with desktop dacs? Cayin C9 wasnโt taking hotter inputs well (higher voltages). I wonder if Tsu can take for example a 9V outputting DAC
bukumurah
I believe I read somewhere on the Brise website that stated a max of 3V input on the Tsuranagi.. but supposedly the lower the better..Has anyone tried pairing Tsuranagi with desktop dacs? Cayin C9 wasnโt taking hotter inputs well (higher voltages). I wonder if Tsu can take for example a 9V outputting DAC
kajetanjazz
Really? Why would that be?but supposedly the lower the better..
I emailed Brise and balanced input can receive up to 6V while single ended 5.1V. Though sth around 3V would probably be perfect
bukumurah
I also have to clue why lower is better.. but I remember reading somewhere that they recommend the source to be set at the lowest possible gainReally? Why would that be?
l Like Music
Anyone tried paring Yatono HP ultimate with Susvara?
HiFiDJ
- Dec 26, 2013
Not specifically, but if your chain isn't too relaxed I think it would pair great. Although, the orochi is a better value since the Japanese yen is low at the moment. The price difference isn't huge.Anyone tried paring Yatono HP ultimate with Susvara?
l Like Music
Thank you for your recommendation. But is Orochi EOL already? I couldnโt find it from their website.Not specifically, but if your chain isn't too relaxed I think it would pair great. Although, the orochi is a better value since the Japanese yen is low at the moment. The price difference isn't huge.
