Then maybe I'm lucky because Mee Audio L shaped 4.4->2.5 converter does not affect sound quality much. I use various 2.5mm terminated cables directly connected to SP1000Cu and through the converter to WM1Z and found that the sound quality is not affected. Of course, sound signature is different between SP1000Cu and WM1Z. But the converter is pretty transparent and does not color/distort sound, or at least I don't notice. My only 4.4mm terminated cable is ALO SXC 8 for Cascade.@ceeloChamp : Normally, a short adaptor effects on SQ, and mostly distort SQ from low margin to high margin. Though in case of a tail-pig adaptor, it will bring better or worse SQ depends on synergy of a tail-pig cable. If you want a 2.5->3.5 adaptor, please consider the Effect Audio adaptor.
The Official 64 Audio Thread | apex & tia Technologies
chaiyuta
@Giraku : Thanks for info. Mee Audio Cable+Adaptor set sounds really a nice deal. Sadly, that Mee Audio set was released after many adaptors made by after market cable companies, and I already own Effect Audio adaptor before. Though I am not disappointed cause I prefer straight-type to L-type.
DrummerLeo
Sponsor: Unique Melody
Hi guys, I’m looking for a cable around $200 or under $300 that can upgrade the transparency and add some treble sparkle for u12, or maybe u18 which I’m considering upgrade to. Any suggestions?
I'd like to wholeheartedly recommend Ted Allen of HeadphoneLounge https://headphonelounge.com/
His cables are nothing less than fantastic: top shelf OCC, Litz type 2 silver and copper, which are both fetching and durable, cut to any size. He offers an assortment of amp and IEM connectors of all grades and looks; creative Y splits, some which are crafted of wood; and finally, his soldering is meticulous and reliable. Truly custom work.
See attached image of an unbalanced copper cable I recently received. My relatively acute ears couldn't detect any aural difference between it and cables of similar architecture but manifold more expensive.
The icing on the cake is their affordability, especially now that he offers 20‰ discount.
Dealing with Ted is a pleasure. He will gladly guide you in the right direction, explain every detail you wish, and try and save money for you without scarifying performance. His communication is prompt and to the point.
A great bang for the buck.
ericr
- Apr 19, 2008
Absolutely loving my Tia! Give me some eartip recommendations. I already have Symbio mandarins, Spiral dots, acoustune AET08, and Final Audio type E's. I know I have a lot, but i'm all about tinkering with new stuff.
The tips from the UE900/s are my favorites - enough so that I'm no longer looking for other tips.
http://pro.ultimateears.com/ue900-s-ear-tips
These generic tips are a close second and are a great value:
https://m.ebay.com/itm/10-Replaceme...hash=item2571d720f9:m:m0zmHlvs6McykOlFaeJAZBg
Eric's tip for tips: find tips where the inner diameter of the exit area of the bore is larger than the outer diameter of the IEM's stem. In other words, the tip should in no way shroud the stem of the IEM.
This has been true for most of the IEMs I have owned, and is especially true with the Tia Fourte. The Fourte's l acoustic chamber is loaded with high & mid Tia drivers and dynamic bass driver. Set it free!
P.S. Deep insertion of the Fourte will make your ear an extension of that acoustic chamber!
chaiyuta
Ortofon tips, Acoustune AET07Absolutely loving my Tia! Give me some eartip recommendations. I already have Symbio mandarins, Spiral dots, acoustune AET08, and Final Audio type E's. I know I have a lot, but i'm all about tinkering with new stuff.
- Feb 1, 2011
Effect Audio Eros II or Toxic Cables Silver Poison
dc655321
- May 16, 2015
That's a great tip. Thank you!
You won't regret getting Ted's Silver litz T2 cable! Had mine for a couple of years and reterminate it when I get new iems. Unheard of turnaround time; a couple of weeks versus the months it usually takes most companies.That's a great tip. Thank you!
I second to that. Effect Audio Eros is excellent in the specified price range.Effect Audio Eros II or Toxic Cables Silver Poison
I bet they are as good as Ted's - - but Ted is half the price....
12t/trio - US Tour Update
Good news, the tour kits for our 12t/trio tour are on the way. I am setting up a tour thread for signups now and will launch this weekend...... stay tuned!
- Oct 6, 2013
To my ears, mee audio adapter does degrade the sound quality, using with U18t. It rolls off the top end a bit, less treble sparkle and airlines. So far, the most transparent 4.4mm adapters I found are from Effect Audio and PlusSound.
Announcing - Trio/12t US Tour Signups
Here we go again! Starting signups now.
https://www.head-fi.org/threads/64-audio-us-ciem-demo-tour-trio-and-12t-starting-march-2018.874900/
