pila405
- Aug 19, 2008
In your measurements it goes to -1.5db at 20KHz, while only at -0.15 on Ohm Image (both NL). How come?
Fwiw: I think it's obvious by looking at a couple of my graphs, however for those who haven't noticed it: My sound card has got a steep low pass filter [starting] around 17-18 kHz, so obviously the number right at 20 kHz is not the actual deviation - my results are "only" accurate up to 18 kHz.
Oh, ok. Wasn't sure because it did pretty good job with the Shinrico SHD5
TUTORIAL:
Requirements:
In theory, now one could start measuring right now, but it is recommended to check whether everything that is necessary is available:
Hardware:
computer (running Windows), audio input (-> soundcard/interface), 3.5 mm (male) to 3.5 mm (male) cable, 3.5 mm stereo to 2x 3.5 mm stereo y-split, DAP (, headphone amplifier in case you want to amplify the signal with hardware instead of with Audacity)
Software:
Audacity, Right Mark Audio Analyzer (RMAA)
Realisation:
Before beginning with the actual measurements, it is recommended to test whether the used equipment (soundcard/audio-interface) records signals linearly and therefore is good for making measurements
Congratulations - you can now perform simple measurements with RMAA.
Btw, I'm looking for the 'verdict criteria', the last column in the summary table where it states the verdict, poor, average, very good, etc.
For example:
Do you have the criteria for those values? I'm curious what is considered poor, average, good, very good, or excellent.
Have been searching for those criteria, but couldn't find it so far.
I guess we will never know for sure unless someone pings RMAA's programmers, looks into the source code or approximates them by performing a large number of tests.
Anyway, the numbers and "verbal remark" are only reliable if the same soundcard, levels during the measuring process and loads are used, because every soundcard will perform differently and also show different results for the parameters that exceed the simple frequency response and frequency deviation measurement.
Walnut V2
DAP/Amp.
hi all,
I just tried RMAA for the first time, and am not sure if I did it correctly, so comments/suggestion welcomed.
all DAPs has EQ turned off, all DAPs volume set around 80%, laptop mic-in volume set to 100% and pre-gain at 0%.
I dont have a 3.5mm Y-splitter, so I am only able to get the unloaded chart.
Walnut at 50% volume (12 o clock position, with 6 o clock being off), laptop mic-in volume adjusted to 20% due to clipping
Walnut at 25% volume (9 o clock position), does this chart illustrate channel imbalance at this volume?
Fiio X3ii
AGPTek M20 (Benjie S5)
Ruizu X02 (AGPTek A02)
here is the info table for all 4 above DAPs
