Alright now I'm getting pretty excited. The hard part is done and now I'm scheming.
1) Going to sand and refinish the cups. Think I'm going to try Minwax Red Mahogany stain and then let them soak in Scarlet Red Rit Dye followed by a shiny clear coat finish.
2) Pop out the screens and replace with a nice fine copper mesh of some sort.
3) Going to build new rodlock blocks out of Mahogany.
4) Moving the RS1 badges up to the rodlock blocks and attaching them.
5) Recabling of course, but still not sure what wire I'm going to use.
6) I may or may not refinish the gimbals that hold the cups in place.
7) Also going to remove the other cheesecloth screen and buff both faces of the driver. I started with one driver already. I'm going to be sanding then using Novus #2. I think the drivers a gorgeous to look at, so I'm not going to replace the cheesecloth.
8) I'm keeping the beautiful condition headband the way it is even though I've got an itch to build another one of a lighter tan color.
@Bill- Hey those look pretty nice.
Before: You can see alot of residue from the glue.
After alittle sanding so far. I need to get some fine grit tomorrow so I haven't polished with the Novus yet.
