Jam_Master_J
- Aug 25, 2003
I'm going to be using a STEPS/TREAD combo to create a 24 and 12V supply to drive my Monica 2 DAC and Millet Hybrid. I'm thinking about using DIN connectors but I'm not really sure what specific type I should be buying.
I'm thinking of using 3 pins (one for ground, one for +12V and one for +24V). For the equipment I'd be using panel mount female jacks and the connecting cables need cable mount male connetors, probably mounted on Starquad or something similar.
Does anyone know of good quality, but not too expensive DIN connectors that fit my needs? I'd like to order from Digi-key if possible.
Thank you,
JMJ
Edit:
Here are some I found, are they good?
http://www.digikey.com/scripts/DkSea...459699&Site=CA
http://www.digikey.com/scripts/DkSea...459679&Site=CA
Thank you,
JMJ
Edit:
