Ivan TT
The ones I've got are 1/2W metal film (the latter IS critical).
Was the buzz introduced during all th capacitor changes or was it always there? Does it have anything to do with the op-amps that are being used or is it inherent in the F1 from the get go?The ones I've got are 1/2W metal film (the latter IS critical).
Was always there, but its not a buzz, but white noise.Was the buzz introduced during all th capacitor changes or was it always there?
Cool thanks....mine are 0.6W metal film.The ones I've got are 1/2W metal film (the latter IS critical).
@Ivan TT Hey, I was wondering...where do you hear the "white noise"? Can you hear it with the volume pot turned all the way down on the F1? I just got the Walnut amp this afternoon, and I can't really hear it. I'm using a Zishan Z2 (with Muses02 in it, if that matters to you). It sounds pretty clean, even with the F1 volume turned all the way up (you know, sending all the power to the caps and all). I have a volume "thingy" in between the line out of the Zishan and the Walnut so that I can toggle the LO and turn up the F1. Here's a pic, so that I can prove I'm not BS'ing! hahaha! It's a volume thingy that actually came with a pair of Shure 500 series earphones. I thought it would work here, and it does without changing the SQ (as far as I can tell by AB'ing with and without it).Was always there, but its not a buzz, but white noise.
The reason is that F1's amp has gain of 11 (as far as I understand) as in "classic" CMOY design, and it wrecks havoc with gain staging when using with Z2's LO, bringing noise floor way too up and reducing the range of the volume pot.
So reducing opamp's gain by adding resistors in parallel brings noise floor down, improves volume range and while there is still a bit of distortion at the top of volume pot travel when using "Power out", there's no noise or distortion when utilising buffered out and volume control range is more effective (and safe).
After this mod my F1 has totally "black" background.
Interesting connection theories there! Hahaha! I think it's neat that you can plug in 3 headphones at the same time and have them all running at the same time from all the open jacks.Yup, I used a similar one that came with UE TF10, 100Om attenuator.
Great minds think the same
To be honest I don't remember the configuration where that white noise was present, but I remember it disappearing after I reduced gain by soldering in those 12k resistors over opamp's terminals, and I think it was present when plugging into F1 power out (the middle one), but not line in (or was it other way around?). Try plugging your Z2 PO into F1's power out?
I have muses02 in my F1, by the way
Better battery is nice and F1 would definitely benefit from it. What is the code on it, cannot quite see on the photo?
As for the caps, it's not uncommon for those DIY devices to use substitutes due to (I assume) their supply chain. Aren't you replacing them anyway though?
I agree....the balanced output is fine - doesn't need clipping....Quick question, does the mod on post #9 reduce the gain only on the 3.5 mm SE, or for both the 2.5 mm and the 3.5 mm?
I quite like how powerful the 2.5mm is already... But i would like to cut the gain of the 3.5mm....
Yes, it reduces input gain of signals feeding thru Line In.I quite like how powerful the 2.5mm is already... But i would like to cut the gain of the 3.5mm....
