Watts Up...?
Jan 8, 2024 at 3:34 AM Post #4,441 of 4,697
The one thing I still don't quite understand is pulse array. I get that you have a number of elements that have all been slightly time shifted such that 2 elements will cancel for any given edge of data, but I don't quite understand how this works.
In my mind, this means you have 10 slightly time shifted signals all arriving at some output. How can these signals sum up to 1 signal if they are all slightly different?
And if the goal is to have a rising edge canceled by a falling edge, wouldn't it make more sense to just have a balanced/differential signal that isn't time shifted? I get that you get some benefit in having multiple elements because it lowers the impedance, but why not run a bunch of differential signals in parallel?
I feel like I am missing something obvious.
Jan 8, 2024 at 7:10 AM Post #4,442 of 4,697
In this video, about 3.5 minutes in, you can sort of see how pulse array works.
The goal is not just to have a bunch of rising edge cancels falling edges but to limit it to only 1 edge cancelling each other all the time (except when the signal changes slightly by 1 edge). Because if you have 8 edges cancelling each other at the same time sometimes and 1 edge cancelling at other times, you’re going to have massive fluctuations causing noise floor modulation and increasing jitter. Moreover, when that happens, often it’ll become signal dependent which causes other sonic artifacts. At least that’s my layman’s understanding.
Jan 8, 2024 at 2:16 PM Post #4,443 of 4,697
I hope I can see Hugo 3 this year. I still love my Hugo, skipped Hugo 2 but after trying all the DAP in the market ( and I do mean all the main stream), I've went back to mu Hugo using optical in, and it just works.
Jan 8, 2024 at 2:32 PM Post #4,444 of 4,697
Thank you for the response. I have watched that video serval times.
I get that one edge is always canceled by just 1 other edge. I even understand how choosing the number of elements is related to the resolution of the PWM signal.
Where I lose the plot is when we look at each element individually.
Each element is essentially a single PWM signal of the whole music signal. In other words, If we could just play a single element out of the array and we would have music on the output. This is how you get matching across all the elements in the array.
But since each element is slightly delayed, each signal will arrive at the output at different times. How is it possible that 10 or 20 slightly different signals all sum up to 1 "correct" signal.
A different way of saying it is how does this function make sense?
((Signal1 + 0t) || (Signal2 + 1t) || (Signal3 + 2t) || (Signal4 + 3t) || (Signal5 + 4t) || (Signal6 + 5t) || (Signal7 + 6t) || (Signal8 + 7t) || (Signal9 + 8t) || (Signal10 + 9t)) = Signal1 + 0t
Where t is not equal to 0.
And again, why go through the trouble of time shifting everything? Wouldn't a differential signal cancel just once at every rising and falling edge without the need for time shifting? I'm not trying to be intentionally dense, but this has been bugging me for years. I saw Mr. Watts presentation a while back at cam jam and I have regretted not asking these questions.
Jan 8, 2024 at 2:46 PM Post #4,445 of 4,697
Jan 8, 2024 at 6:06 PM Post #4,446 of 4,697
The elements are not mathematical objects but physical switches so it’s impossible for the elements to be identical. That means signal1 is not perfectly equal to signal 2 and 3 and 4 and 5. Most DACs use some form of dynamic element matching so that if you just a signal level of 1 (out of 10) instead of always firing signal 1, you would sometimes fire signal 2 or 3 or 4 or 5. That way it evens out the errors amongst the elements.
As to why a differential signal approach is not equivalent to a constant switching approach, you can think of it this way.
Let’s imagine a signal of 000111
So in differential signal, you’ll actually have 000111 on one end and 000-1-1-1 on the other end which is basically still 000111
In a constant switching scheme, to get 000111
Flip up 111111
Flip down 111011
But in a differential scheme
Flip up 000100
Flip down 000000 for the positive end
Flip up 000000
Flip down 000100 for the negative end
So what you’re saying is that it’s the same thing because the differential scheme canceled each other.
Except when the elements are not flipping, they have a different energy level and less noise than when the elements are flipping. And flipping up and down also tend to have slightly different levels of energy. These slight differences would generate varying degrees of noise.
so far, we are dealing with a small signal change. If we are going from super quiet to super loud in a differential scheme then suddenly you’re going to have signal dependent noise because you only need to switch when the music is loud and you don’t switch much when the music is soft.
This is why constant switching schemes tend to have lower levels of jitter and noise floor modulation.
Like I said, I’m thinking about this like a layman so my explanations are very clumsy. But I hope this makes sense.
Jan 8, 2024 at 6:38 PM Post #4,447 of 4,697
Flip up 111111
Flip down 111011
Flip up 000100
Flip up 000000
Yeup. Im stupid. When you put it in terms of the data stream it makes perfect sense why differential is not a thing. I should have known that too.
The first part though is something new. I'm not familiar with dynamic element matching. This might be where Im getting lost and how 10 elements equals somehow equals 1 output.
Jan 9, 2024 at 8:20 AM Post #4,448 of 4,697
Dear Mr. @Rob Watts, following @stemiki and @miketlse advise on how to best address the absence of a optical connection on my Stack Audio Link II streamer, I bought a Topping D10S to use as a digital connection between the streamer and the M Scaler using the BixPower batteries pack. The USB Out on the streamer is connected to USB In on the Topping and then from the Topping Optical Out to the M Scaler Optical In. The problem is that sometimes there's a "hiccup" at the beginning of a song, especially if the sampling rate changes. Also, I have noticed that while playing Gina Alice's Wonderworld from Qobuz (24Bit/192kHz) there is no sound at all, just complete silence and there's no light (of any colour) in the DX OP, but if I play the Tidal's MQA version, it plays as usual. I should mention that the Topping's display while playing the Qobuz version shows, as it should, 192kHz PCM and the Tidal version 48kHz. Any idea what must be wrong? Many thanks in advance.
Jan 9, 2024 at 12:44 PM Post #4,449 of 4,697
Feb 27, 2024 at 12:57 PM Post #4,452 of 4,697
Since that video was deleted, the replacement is:
This is "editorialised" and I think some of what Rob said has been lost when compared with the original, but I'm not sure.
Quartet Scaler:
  • 5 FPGAs of the same type as in the Hugo M Scaler
  • 4 million taps
  • separate power supply
  • high power consumption
  • improved filtering for BNC outputs
Feb 27, 2024 at 2:09 PM Post #4,453 of 4,697
Quartet Scaler:
  • 4 million taps
And said will be launced at Munich in may
Thanks for sharing J.
Lol and Ultima DAC next year following John
Feb 27, 2024 at 2:50 PM Post #4,454 of 4,697
£9,995.00 GBP perhaps…
  • Back
