Marximus
- Feb 28, 2007
AKG K 601s or Bose AE2 are the most comfortable that I've tried.
Comfort is NOT subjective!!! There are a variety of objective factors that can be considered when talking about comfort: clamping force, overall headphone weight, weight distribution over the headband, headband material, earcup material, and earcup depth & diameter. The importance of these variables to the user can be subjective.
For open headphones, I personally found the Hifiman HE-560 to be extremely comfortable. Comfort specs for the HE-560 are top-notch as well. Clamping force is not too tight, light-weight for orthodynamic headphones at 390g, weight is distributed symmetrically due to suspension style headband, velour used in earpads, earcup dimensions are 55mm diameter with 20 to >25mm depth for the angled earpads. The Oppo PM-1 is another great contender for comfort with real lambskin leather used, but I personally think that the HE-560 suspension headband system edges it out over the PM-1. That is the subjective spin of which variable is more important to you personally.
I would love to see how other "comfortable headphones" match up against my two personal picks in terms of comfort-specs!!! I have not tried all the headphones out there, so if another pair of headphones out-spec my choices in the comfort department, I will gladly admit defeat. However, there is an objective systematic way we can measure comfort and I think that headphone manufacturers will benefit from approaching comfort with this mindset as well.
