Yukicore
- Oct 20, 2013
Hello, I've recently purchased headphones, they're mostly plastic, and make creaks when I move the hinges. I used a silicone spray on the hinges, which was quite a big mistake, I thought that I would even out and make for a good lubricant, while it has been worse than before.
I use the spray on mouse-pad to keep the glide nice and smooth, turns out in moving plastic parts it doesn't work, it sticks.
What product should I use? I've found DuPont Dry Teflon lube, Would that work?
