lumzi23
- Jun 26, 2013
Hello,
I want to get a Hifiman Deva Pro but I am unsure about the cable. Would a standard cable like this work?
On the Hifiman page (you have to scroll down a bit), it says it can accommodate a dual-sided unbalanced 3.5mm cable and a single-sided 3.5mm balanced cable. In the same place, it shows a picture of a Dual 3.5 mm TRS cable and a Single 3.5 mm TRRS cable. But I don't understand about balanced or unbalanced cables but according to what I have seen on the internet TRS cables are balanced NOT unbalanced. Please help.
Also what cables do the headphones come with? Dual TRS or Single TRRS?
Edit: I just noticed that this might be the wrong place for this. Should I recreate this in Help & Recommendations Forum or can a mod move it if they have the power?
