[size=x-small][size=x-small]Pretty enlightening stuff, I'll definitely check out the [/size][/size][size=x-small][size=x-small]Alfred Tomatis' theories[/size][/size][size=x-small][size=x-small] at some stage. As always with audio there are several trains of thought and no defininite answer. So am I right in saying that the theory behind a DAC is to reproduce the source material as accurately as possible, but in practice this is not the case. Whether it be manufacterers deliberately manipulating the sound or just a natural by product of what parts they use. [/size][/size]
[size=x-small][size=x-small]The DacMagic itself has 3 different filters which are meant to change the sound (personally I have trouble discerning the differences) and this in itself contradicts what I initially thought was the purpose of a DAC. [/size][/size][size=x-small][size=x-small]Theres also another group of people who believe that DACs are largely the same once you get to a certain price threshold ie. Any decent stand alone DAC above entry sound pretty much the same.[/size][/size]
Close but no cigar. I've discovered that almost everything has some sort of sound signature. I have a bunch of dacs (see profile) and although they sound similar, they don't sound
exactly the same. The biggest difference is in resolution, space and air and where you are sitting in relation to the stage. My Stello, for instance, seats you closer to the stage than my North Star and the North Star has a greater resolution than the Stello. My older DAC-AH sounds flat and unresolving compared to them. I have a Constantine which I use for cable TV but it doesn't have the resolution and depth of the North Star.
I've experimented with transports for a laptop rig and found the USB Blue Circle Thingee, sounds pretty much the same as MB optical out of a pair of Shuttles I built. I tried the HiFace, but it played louder than the BCT and had a treble tilt that altered the tone of instruments and vocals in a way that I didn't like, relative to the BCT I also felt that the treble tilt, or brightness, created pseudo-details rather than greater resolution, so I don't use it. The North Star dac I was using it with is an upsampling dac and apparently upsampling dacs neutralize the low jitter effects of the HF so there was little going for it. The other problem with the HF was that because it played louder, it was easy to fall into the "louder sounds better" mode. Volume balancing showed that it was just brighter, or as I said before, treble tilted and didn't sound realistic because of it. There was a bigger difference between these transports than between the Constantine, Stello and North Star dacs.
The other thing I found was that the onboard USB converters in the Stello and Constantine were pretty bad and easily beaten by the BCT.
I auditioned the Neko dac and volume balanced it against the Stello using my two identical Shuttle computers only to find that I really couldn't tell those two apart. At a meet we compared the Stello to a non usb Benchmark I using the BCT (which as dual outputs) and although there might have been slight differences, it was too close to call at the meet. But if I had more time with the dacs, sound stage, depth and resolution might have separated them.
So to get to the "decent dac" level where things start to sound very similar, you're probably looking at around 1k to 2k. The cheaper dacs are lesser dacs but not by the orders of magnitude of their prices.
And don't get me started on amps. I have 3. My Woo3 and my M^3 (637/627) have pretty much the same sound signature while the GS-1 has more resolution (clarity) and sound stage than the other two. Of course that's an over simplification, but it will do for this post.
The only thing that sounds the same is wire: power cords, interconnects and cables.
YMMV
USG
