Hi....I like to know this info, As per review on the net people are mentioning when using as USB DAC for PC need to connect the charger to the Micro USB port, Is it mandatory?
XDuoo XD-05 Portable Dac/Amp Introduction - Impressions
- Thread starter H20Fidelity
- Tags
- xduoo
not necessarily. you can use the dac with its own battery, and charge it overnight.Hi....I like to know this info, As per review on the net people are mentioning when using as USB DAC for PC need to connect the charger to the Micro USB port, Is it mandatory?
imran27
- Sep 22, 2014
Does the XD-05 support MQA?
imran27
- Sep 22, 2014
Smithington
- Nov 20, 2014
No it does not. I doubt it will either.
JayceOoi
- Oct 1, 2015
Anyone interested in getting XDuoo XD, do check this out - $138.99 with coupon - XD05
http://www.gearbest.com/mp3-mp4-players/pp_389744.html
Hi - I just received the XD-05 and download and install TUB driver v3340 as mentioned on the previous page and I'm getting only '16bit 192Khz Studio Quality' - Is this highest?
UPDATE :- Apologies for the above noob question - Found the solution, need to set the format at TUSB Audio Control panel.
Hello Guys.....Please let me know what kind of 3.5mm adopter required for XD-05 to get the coaxial signal?
Trying to connect X5-2nd Gen which got a 4 pole Coax plug but the XD-05 definitely not recognize a 4 pole 3.5mm coax signal at its side....please let me know.
Holypal
- Mar 1, 2016
The 4-pole plug into Fiio X5-2nd, and the other side is a 3-pole plug into XD-05. At the same time, the input switch on XD-05 should be on the left.
Thanks for the reply - Yes I switch the input to Coax position - The Problem is I didn't find a single cable with 3.5mm 3 pole with single male RCA or Female RCA...all I'm getting like this
All I need only one RCA male....I doubt with 2 RCA will work.
I think this is what you are looking for: https://www.amazon.com/Extreme-Audio-Digital-Connection-Generation/dp/B01AF98IY0/
@Ab10, and here's one that is a little better rated, in fact, it seems to be the bonafide FiiO-branded cable:
https://www.amazon.com/dp/B019OWCID6/
@trellus these won't work either as the rca won't fit the digital input on the xd-05. that's more like it:
https://www.headfoniastore.com/shop...coax-cable-for-fiio-x5-ii-x3-ii-to-fiio-e17k/
@s4tch Thanks for the correction, don't have one of these, and was just answering based on the user's selection of RCA as plug type for one end, sorry!
pesci1234
- Sep 23, 2013
Hi all xduoo expert
I need some advice
Just received an xduoo xd 05 and i pair it with my iphone 6 with camera kit but i don t understand why xduoo doesn t by pass the iphone dac
My fiio q1mkii with the lighting connector allows me to drive the volume with the q1 mkII and the iphone volume has any effect ,
with the xduoo the volume button on my iphone still have an effect
why ?
thanks for your answer
I need some advice
why ?
