Gilroypro
It's not bad on Aptx adaptive Hi-Res though. If the TWS and transmitter have Aptx Lossless as a feature. With Aptx Adaptive 24/96 the bitrate increases to 880kbps instead of the regular 420kbps
So tempting...The Avantree LE receiver will be available 10 days. Would really love to know how the aptx lite sounds(I need low latency for my subwoofer vest) but I can't, as I have pre-ordered the transmitter+receiver combo months in advance for an extreme discount, it's almost free. If anyone buys this plz let us know about aptx lite...
https://avantree.com/as70p-bluetooth-adapter-for-headphones
The Eppfun AK3040 Pro Max USB C transmitter also will meet the requirements of the New Qualcomm S3 & S5 Gen 3 platform standards. As the dongle has classic Bluetooth and LE works along side Aptx Lossless. In terms it is capable of ruining the new Aptx Lossless Hi-Res (1,200kbps bit-rate, 24 bit at 48khz sample-rate) Works on my Vivo TWS 4 Hifi. Will work too once Sennheiser updates it into the MTW4
I am too. That's Aptx lossless at 16 bit at 44khz sample-rate. Not the newer 24-bit at 48khzI'm already using AptX Lossless on my MTW4. Had to enable it in the settings within the Sennheiser app on my phone, but it's on there.
Hmm. I'm using the FlooGoo FMA120, set to 24/48, but I do see now in the app that it shows 16/44.1. Though at 1200kbps wouldn't 16/44.1 go beyond maxing it out anyway? Is there a higher bitrate version at 24/48 coming or am I missing something?I am too. That's Aptx lossless at 16 bit at 44khz sample-rate. Not the newer 24-bit at 48khz
The TWS and a device like a phone need to meet these requirements to get Aptx Lossless Hi-Res. The Eppfun transmitter and the Vivo TWS 4 Hifi are both capable. Been enjoying the experience. The MTW4 has this SoC but needs a firmware update to unlock itHmm. I'm using the FlooGoo FMA120, set to 24/48, but I do see now in the app that it shows 16/44.1. Thought at 1200kbps wouldn't 16/44.1 go beyond maxing it out anyway? Is there a higher bitrate version at 24/48 coming or am I missing something?
I guess I'm a bit confused on how sound quality can be improved in this instance, if the bitrate remains 1,200kbps. Even at 16/44.1 that's not quite lossless since the bitrate for that file would theoretically be 1,411? 24/48 would only require more compression, wouldn't it? I'm not as informed as a lot of you guys are on bluetooth stuff so I'd love to be corrected. I wish they published clearer information on these changes.The TWS and a device like a phone need to meet these requirements to get Aptx Lossless Hi-Res. The Eppfun transmitter and the Vivo TWS 4 Hifi are both capable. Been enjoying the experience. The MTW4 has this SoC but needs a firmware update to unlock it
https://www.qualcomm.com/products/internet-of-things/consumer/audio/qualcomm-s3-gen-3-sound-platform
Aptx lossless is very close to full CD lossless. Might or might not be more compression being added. BT5.4 is newer and is better optimized and uses better efficiency from previous versions. Think Qualcomm found a way to cleverly utilize BT5.4 and LE Audio to work together to be able to increase Aptx Lossless sample-rate. Well from my understanding from what they advertise. I do notice better depth audio with adding 24/48 to Aptx lossless from the regular oneI guess I'm a bit confused on how sound quality can be improved in this instance, if the bitrate remains 1,200kbps. Even at 16/44.1 that's not quite lossless since the bitrate for that file would theoretically be 1,411? 24/48 would only require more compression, wouldn't it? I'm not as informed as a lot of you guys are on bluetooth stuff so I'd love to be corrected. I wish they published clearer information on these changes.
MTW4 support 16bit/44.1khz now with qcc5181(s5 gen2),so it seems not supported 24but/48khz.The TWS and a device like a phone need to meet these requirements to get Aptx Lossless Hi-Res. The Eppfun transmitter and the Vivo TWS 4 Hifi are both capable. Been enjoying the experience. The MTW4 has this SoC but needs a firmware update to unlock it
The stream gets encoded(compressed) at the transmitter side, sent to the receiver at lower rate than 1411(ive seen FLACs at around 700-800kbps), and decoded(decompressed) at the receiver side.Even at 16/44.1 that's not quite lossless since the bitrate for that file would theoretically be 1,411
