Some FPGA firmware upgrade readme suggest upgrading Amanero module to the latest version. It means synchronisaton of firmware.
I apologise for an assumption. Did you experience DSD problem from the beginning or only after attempting of firmware update? Did you try upgrading firmware on any DA-8 module?
I remember that you reported problem with PCM as well, happy to hear it is solved. I asked sometime ago what is a setup for the output word size in Foobar, didn't get reply. Check it out. Also try ASIO. It may be still configuration error.
_No PCM files played always very well from the beginning.
_DSD files or the conversion from PCM to DSD by software or hardware source always played with a lot of noise.
_I tried to upgrade the firmware due to this issue.
I purchased the kit with USB, HDMI modules and Altera Usb interface directly from Audio GD, as suggested by Kingwa, in order to get the upgrade to 2021 edition.. . USB isolation, a different mangenent of clock and other benefits as you know.
As just said
the issue of noise by DSD occurs also with other hardware source with I2s connection and by USB with all bit perfect software players (also HQP layer), with right setting, believe me about that.
Noise only in the right channel.
In conclusion
The only chance is the upgrade, but till now it was a fail because of drivers issue or Altera usb Rev c issue sent by Kingwa.
OK any suggestion is well accepted.
1. Easier with a win 7 pc.
2. I followed the instructions by Audio gd.....tried different drivers as suggested in different posts of internet forum...
I understand that is not enough to get altera usb in device manager. I must get also Jtag interface.
Till now the jtag chain was not checked by Quartus software.
I used Quartus II 16 downloaded by Dropbox indicated by Audio GD with PDF files instruction.
I tried a previous version 13.1 version founded in internet (drivers not loaded) .
Anyway I don't understand it's so difficult an upgrade. My R28 has the connection inside the chassis. The cable was correctly connected as suggested. I performed a lot of firmware upgrade for different devices during past years.
Thus, I hope in forum support for the upgrade. Till now I checked a lot of post....
Thanks in advance
