Beyerdynamic DT 1990 PRO - Beyer's open-back mastering headphone
Apr 24, 2024 at 9:15 AM Post #4,771 of 4,782
I use graphic or parametric EQ on my various Mac players to minimise the disturbing peak.
What EQ do you use? I know you have some AU plugin, but what app does it work with? I haven't been able to figure it out.
Apr 25, 2024 at 5:28 PM Post #4,774 of 4,782
Hello...I listen to a lot of classical music and piano jazz (Keith Jarrett, Pollini, Ashkenazy, Trifonov, etc.). Which headphones , Only Beyerdynamic or Philips (max 600$) do you recommend?
I'm thinking you'd be better off with some of Beyer's warmer headphones. Amiron Home or the T1
Apr 26, 2024 at 2:36 AM Post #4,776 of 4,782
I sniped a 2nd handed dt1990 in great condition. Only swapped to the amiron wireless dust protector and using the balanced pads. Excellent value for what you pay nowadays. The build quality is outstanding, same for comfort and overall sound quality. You can turn it into a treble monster in order to master or a balanced audiophile pleasure device by swapping pads and dust covers.
A great chameleon!
Apr 27, 2024 at 9:06 AM Post #4,778 of 4,782
Dt 1990 pro or Amiron Home? T1 1gen, 2gen or 3?
This is the problem....
1990 is really energetic, the balanced pads kinda raise the mids up but IMO they get muffled as opposed to warm. The Amiron is warm and detailed but more energetic like the 1990. Jazz and classical, acoustic stuff sounds great on the amiron
Apr 27, 2024 at 12:27 PM Post #4,780 of 4,782
I had the Amiron in-house for two weeks and returned it. A friend has the T1-Gen3. I am not a fan of the Beyerdynamic "consumer" sound profile, as found in the T1-3 and Amiron. I much prefer the harder hitting DT 1990 sound, and only with Analytical pads.
May 1, 2024 at 11:15 AM Post #4,782 of 4,782
I'm waiting for the Beyerdynamic Dt 1990 Pro which i will use with Meier Corda Jazz-FF and CDP Lector 06 (tube cdp), what do you think?​
You tell us what YOU think when you hear it 😉 lol
