About the same as I remember the DT 990 Pro being in terms of quality of plastics and materials. The sliders do seem more snug and adjust nicer and don’t feel as loose as they did on DT 880/990’s so they should retain their adjustability better so I would say the tolerances on the sliders are indeed better.What is the fit and finish like on this 100th Anniversary model?
Are the tolerances tighter on the sliders so they are not a potential fail point like on the previous 770 models?
Also, is the wire noticeable being single sided (in the context of weight of cable)
Compared to the other stellar.45 headphones. Build quality of the DT 700 and DT 900 Pro X is better and they also have a tighter clamp than the DT 770 Pro X. Comfort overall I think the DT 770 Pro X is more comfortable but I like the pads more on the DT 700 and DT 900 Pro X.
Don’t really notice the weight of the cable.
