lmfboy01
- Apr 26, 2007
I get both today will check it out
I had Soundmagic ES18, Vsonic GR06, Xiaomi Piston v2, Dunu DN900.
I was not impressed with the price / quality of Dunu DN900 and GR06 seemed uncomfortable.
I will not invest a lot of money currently for in-ear headphones , because i don't have acceptable player/eq.
The headphones that i will buy , I will use them to phone: Xiaomi mi3 and to the computer which has no audio card.
Sorry for my English
but are they comfortable?
I understood, but other headphones that you can recommend about the price $ 18
Best buy will be piston 3 , if i'm listening to rap and i don't have EQ?
How are KZ headphones in-ear?
So even though my Easy orders from March 29th and 31st still have no tracking info, I just received my QKZ DM3 that I ordered on April 6th. So if there are shipping issues in China, it isn't universal.
I just started burning the QKZ DM3, but I can say that it does sound like the Banjo did before burn in...good quality but too bass heavy. I'll see if it changes for the better like the Banjo did, and then eventually compare if I think it is actually the same driver or not. Definitely a great deal at the $6 intro price. I see it has already gone up to over $8 though. Note that this is equal in cable quality and durability to my most durable IEMs.
So, I've been doing further research and checking what makes the HLSX-808 different from the i.Valux/Bette and this is what I got.
These are taken from Aliexpress web pages and they are stated the same way on taobao website.
i.Valux/Bette
i.Valux Hybrid 10mm Dynamic+Balanced Armature (BA) Dual-Driver HiFi In-Ear Monitor IEMS Headphone Earphone Earbud Headsets
Specifications:
- Brand: i.Valux
- Driver Unit: 10mm Dynamic Driver + Balanced Armature Unit
- Impedance: 32 OHM
- Frequency Response: 5 Hz-28000 Hz
- Sensitivity: 112 dB/1mw
- Plug: 3.5mm Stereo Gold-plated plug
- Cable length: 1.25m
- Color: Blue
http://www.aliexpress.com/item/Bette-Hybrid-10mm-Dynamic-Balanced-Armature-BA-Dual-Driver-HiFi-In-Ear-Monitor-IEMS-Headphone-Earphone/32424298027.html?spm=2114.30010308.3.11.KkN2ct&ws_ab_test=searchweb201556_6,searchweb201602_5_10017_10005_10006_10034_10021_507_10022_508_10020_10018_10019,searchweb201603_2&btsid=d5c46321-9f90-4608-9f4a-838473bd093e
NEXT:
HLSX-808
2016 Original HLSX-- 808 HLSX-- 18 Hybridd In Ear Earphone Dual Driver BA With DD HIFI Headphones Double Unit In Ear Headset
Specifications:
Transducer Principle: 10mm Dynamic with AFX BA driver
Driver Diameter: Ø10mm
Impedance: 17 ohm
Sensitivity: 108dB
Frequency Response: 8Hz-25kHz
Color: Red no mic/blue no mic/Gold no mic
http://www.aliexpress.com/item/2016-Origina-HLSX-808-HLSX-18-Hybridd-In-Ear-Earphone-Dual-Driver-BA-With-DD-HIFI/32651444226.html?aff_platform=aaf&sk=bm2aeAra%3A&cpt=1460511303004&af=6146845&cn=002&cv=10925486&dp=imy6pv4ezk000k6o008sc&PID=6146845&URL=http%3A%2F%2Fwww.aliexpress.com%2Fitem%2F2016-Origina-HLSX-808-HLSX-18-Hybridd-In-Ear-Earphone-Dual-Driver-BA-With-DD-HIFI%2F32651444226.html&aff_trace_key=5736aeabe69347cca407e7f2dbe375a9-1460511303004-02015-bm2aeAra
I'm sure because of the difference in specs and the difference in their names, the above reviews have been totally in contrast. And because of this, I concluded that they might not have the same BA and dynamic drivers (or just carry different crossovers).
For example: I own the HLSX-808 and not the i.Valux/Bette, so my question is? .....What's an AFX BA driver?
.....If no one provides an answer, I'll probably just have one of my Chinese friends contact a representative that sells the HLSX-808 from taobao website.
Tennmak Banjo and Rock Zircon are interesting. Really better than Xiaomi Hybrid/Piston 3?
