fooltoque
I decided to look at the few PK shells I have and of course found a variant which has the notch at both top and bottom. This is the shell that shipped with the 120Ω Bery drivers. The diameter is a little bit bigger and an older style PK driver cover is slightly smaller and does not fit. The diameter of the cover for the 120Ω Bery driver is slightly bigger, so fit this shell perfectly, but is a little loose on other PK shells. Some extra confusion, I guess just be aware that PK shell size and features are not uniform. I believe this is talked about in this thread somewhere.
The covers for the drivers I bought don't fit the shell very well either. Luckily they are larger than the shell and not smaller, so it is a problem that can be fixed with glue.
Yeah, better comfort and vent system than PK's.
Also these day it's almost impossible to find OG PK shells (two vents and side wings on shell lip)
What I hate most about PK shells is the narrow cables hole
I don't have any cables that fit, so my build is on hold until one arrives.
All these variants on Ali are disaster,. These two notches on your shell are causing pressure leakage.
I find similar thing on some Nokia shells (they have even smaller notches on top and bottom) and because of it they sound very bad
One of solutions, you can glue a small piece of EVA foam or piece of rubber band on these notches
I was wondering about that, since those notches are so big. I guess gluing different colored rubber bands on might make for nice L/R indicators.
