I also use shrink tube. @furyossa do you remember?
DIY Earbuds
- Thread starter gwompki
Hello Thread!
If you guys allow me, i'll shower you with questions:
I saw a driver on aliexpress, which I didn't see commented on here, it claims to be made of molybdenum. Has anyone tried this one yet?
https://a.aliexpress.com/_mKSohJk
Has anyone tried both huayunxin shells (Wind Chime and Waist Drum)?
Wind Chime
https://a.aliexpress.com/_mrP7HFk
Waist Drum
https://a.aliexpress.com/_mKPJRzY
Any impressions about the sound, and assembly process of these would be very helpful.
Do you think there's much of a difference between 32 and 300 DLC?
https://a.aliexpress.com/_m0NRi9y
Sorry for this wall of questions, any help is much appreciated. Thanks in advance!
Wind Chime
Waist Drum
Kyonnie
I'm also very curious about how they sound. But in theory, it should sound identical to what a beryllium driver sounds like..Hello Thread!
https://metals.comparenature.com/en/beryllium-vs-molybdenum/comparison-25-34-0
I've tried both; they're both really comfortable to me, so I get better bass because of that. Also the flat wall inside causes noticeable reverbs, and you can't use thick internal wiring other than it's pretty straightforward to assemble.Has anyone tried both huayunxin shells (Wind Chime and Waist Drum)?
Wind Chime
Waist Drum
300ohm DLC sounds significantly better to me.Do you think there's much of a difference between 32 and 300 DLC?
It's fine! I hope that I helped.Sorry for this wall of questions, any help is much appreciated. Thanks in advance!
Do you think any of the two shells boost any frequencies more than the other?I've tried both; they're both really comfortable to me, so I get better bass because of that. Also the flat wall inside causes noticeable reverbs, and you can't use thick internal wiring other than it's pretty straightforward to assemble.
There's any way to deal with these reverberations?
It in fact helped, thank you!It's fine! I hope that I helped.
Into The Light5
Is reverb a bad thing? Im about to buy the chime, pairing it with 18 ohm pu+composite. Also, does it offer better soundstage than the usual mx500 housing?I'm also very curious about how they sound. But in theory, it should sound identical to what a beryllium driver sounds like..
Kyonnie
It's very dependent on driver and shell synergy, and the fitment in your ear can cause it to sound different. But in my experience they boost the bass. They're pretty similar internally.Do you think any of the two shells boost any frequencies more than the other?
You can use full foam covers, cut them, and place them on that flat wall inside, or you can use these instead.There's any way to deal with these reverberations?
It depends if you like the echoey sound lol.Is reverb a bad thing?
The thing with MX500 shells is that they pair well with a lot of drivers, so I can't really say, but with my limited experience, the MX500 has a better soundstage.Im about to buy the chime, pairing it with 18 ohm pu+composite. Also, does it offer better soundstage than the usual mx500 housing?
Kyonnie
I read a lot of your old posts, and I really appreciate whenever you make diagrams for them; it really helps me understand the process in more detail. I really learned a lot from you guys in here.
Into The Light5
Finally arrived, lets goo!!! Planning to sell 4 of them but the same cable color only have 3 in stock. Actually an old 2020 project to make some diy buds to sell them, but just finally got the guts in 2024 early
Also i never thought drilling a hole for vent is soo hard, so many failed attempts, i hope everything are smooth and as planned
Mr.HiAudio
Member of the Trade: RIOBuds
Nice!My new creation, titanium diaphragm, 32ohm
these are mine, with mmcx.
And 14mm Tesla:
Sounds like a BA iems, mids like a 10 BA , cool.
And:
Kamikaze777
They look gorgeus.Nice!
And 14mm Tesla:
And:
You have custom printed shells?
I do like also these shells.
Mr.HiAudio
Yes:They look gorgeus.
https://www.head-fi.org/threads/earbuds-round-up.441400/page-4439#post-17249223
I released version 3.1 not so long ago for my friends, everyone can print it for themselves
Kamikaze777
Nice! And a BIG thanks, will definetly try them out!Yes:
Mr.HiAudio 3D printed resin shells are some of the best fitting / most comfortable I have tried. They also appear to have a really "neutral" character - in other words they don't add or take anything away from the sound. Highly recommended.Yes:
Total: 7 (members: 1, guests: 6)
