Earbuds Round-Up
Nov 23, 2019 at 1:28 PM Post #46,036 of 75,742
On Penon the Rose Masya Mk 2 is called the Rose Masya Pro. I bought it from Penon and for some reason they call it the pro. I had to draw it to their attention that they had the wrong figures up for the Mk2. They have now been corrected. I have quite a few IEMs and Buds and can say that I listen to two generally. The Rose Masya Mk2 and the Blon 03. You could very possibly get a discount if you ask.
This is how I got confused. I was told I was getting the Pro. It even had the "Pro" photo on the box, but is labled the MK2 and had the MK2 inside.
Nov 23, 2019 at 1:39 PM Post #46,037 of 75,742
Can aynone suggest me good earbud under 15$ ? I have snow lotus 1.0 and its pretty good but
I want to try something new :)
Get the K's 300
Nov 23, 2019 at 2:19 PM Post #46,039 of 75,742
There was never a pro. It was always either the Rose Masya or the Rose Masya Mk2. Penon called them the Pro, but on the box it was Mk2. Don't know what Penon was doing.
I bought my Rose Masya from someone else who may have also gotten it used. Is there a way to know what version this one is?
Nov 23, 2019 at 3:01 PM Post #46,041 of 75,742
Nov 23, 2019 at 3:06 PM Post #46,043 of 75,742
The only problem with Rose earbuds is they are pretty big and take some getting used to in the ear. But it's worth it.
I don't find them to be as big as they look. That flat outer part is not in the ear. The part that is in my ear just slots in. The person I bought mine from could not get a fit.
Nov 23, 2019 at 3:15 PM Post #46,044 of 75,742
It is so strange, at first I really struggled with fit, but now they seem just fine. Though ears do change over time, I must be getting old.
Nov 23, 2019 at 3:29 PM Post #46,046 of 75,742
You'll know you're getting old, when the hair growing out of your ears provides a cushion for your earbuds... :wink: :ksc75smile:
Nov 23, 2019 at 3:36 PM Post #46,047 of 75,742
Maybe all good things require a bit of effort. The Rose Masya's are well worth that effort. They are also very efficient and easily driven, have a 'big' sound and plenty of low end. Maybe a little pricey but I think they are worth it.
Nov 23, 2019 at 3:44 PM Post #46,050 of 75,742
Actually that's true. I got a tiny chip on the varnish the first day I got them.
The plastic used literally begins to deteriorate in the longterm. Both my Masya and Mojito have showed signs of it.
Hopefully they get their act together for the latests products. They need to change the type of 3d printing matierial they use.
