xneakers
- Feb 8, 2007
how do you find the upgrade on Audyn? I guess should be a jump vs original caps?First pic with the bigger (0.47) mundorf silver supreme I saved from the phono stage on the 8550 pre.. it didnt fit the 8900 by a smudge, the board underneath didnt let all close in. Had to swap to the Audyn Copper Max 0.1
Other upgrades include silver solders, Allen Bradley / Dale resistors and a few capacitors; Im not the builder. I did buy a wrong potentiometer and furutech NFC plugs that also wouldnt fit.
Am playing mostly with speakers with some good new 300B but already tested with the HD800 and wow!! Also will need to test with the supposedly better NOS 2a3. Will need much more time with it for burn in and to further compare with my beloved CFA3. However, this is 220v and the 8900 is 115v, so a side by side is really unlikely in the short term
And which 300B you are using?
