Yep it was a worthwhile sidetrack paired with the Duelund silver foil bypass there really isn't much to grumble about and some of that unique flavour of the K75-10 does come though. What was quiet noticeable going from the V-Cap cutf to the PIO was that familiar ease of presentation the PIO have compared to modern MPK caps.
With the K75-10 mounted on top of the PCB
the capacitors sit a couple of mm to high for the metal top cover to fit as it should I could add a spacer on the fixing points or there looks to be room to mount them on the underside of the PCB.
They have had close to two hundred hours run time so should be well run.
Will switch back to the Cutf again at some point but am on no hurry at the mo.
