Hi
@]eep thanks so much for your insights. I always thought there is something "off" about ASR, but could figure out what. After your explanation, it has all become clear. Thank goodness I did not base my decision on the "gospel" over there
For the time being, I plan on feeding A6 into my AVR using RCA to bypass all internal processing of the AVR. Later, when I upgrade to an AVR with XLR inputs, then I will use the balanced outputs of the A6.
Your list of Master Edition benefits does not include the RCA outputs of the A6, should I assume that the RCA output will also benefit from the better internals of the Master Edition?
Thanks for this great piece of advice, about saving for longer to get a better unit. On the other hand, your point about picking a DAC with different flavors is tempting too.
My question is, I have read a lot about AKM's "high definition" output so this might be something I pair to the A6, but what is the best way to get an idea of the AKM sound signature to see if I will really like it? One way is to buy from Amazon and return but I don't want my account to be blacklisted due to excessive returns unless it's absolutely necessary but local dealers don't carry any AKM DACs for listening tests.
Thanks for this advice again of being patient. Perhaps I will be happy with the Master Edition for a while, and then look for opportunities to pair it with a unique DAC.
Absolutely helps! At least now I can make informed decisions.
