Louisiana
Thank you VERY much, searched for about an hour...Yep, purchased mine on eBay from Xuling Audio Labs
How can you order the tubes outside from the US or Canada?Hello,
here is my review of the 6SN7 Select from Apos Audio.
The review was made with the Euforia and should be of interest to you.
https://www.head-fi.org/showcase/6sn7-select-ray-from-apos-audio.27017/reviews
Apos Audio's latest craze is also online:
https://apos.audio/products/apos-ray-vacuum-tube-6sn7-reserve?_pos=3&_sid=c26d16cdd&_ss=r
I already love the look of the tube and am confident that it is also very good.
You should definitely think about the Select, which is worthwhile for the Euforia as well as the Elise.
I found it better than the Ps Vane tube. And is actually one of the best new stock tubes.
@Louisiana
Deyan makes Adapters too for the Euforia/Elise.
With his adapters you can drive 6v6 als driver tubes,output El34,Kt 66/88 and some more.
But ask him, my adapters was made a long time ago
Hello,How can you order the tubes outside from the US or Canada?
Hello,Hi guys!
I am desperately looking for a matching AMP for my Utopia OG.
My DAC is a Ferrum Wandla which I currently use with my trusty old V200, which sounds good but not outstanding.
Is the Euforia Evo worth it over the OG Euforia? The latter can be had used for around 1k.
Euforia Evo going for substantially more.
I think Wandla has also pretty good SE outputs.
Mine is in there too, but it's a bit better than the standard classic.
Because it has better capacitors.
Thank you, I'll look into thisMost likely DC noise.
As @incredulousity said, it's probably DC noise coming from your mains. Easiest way to check this is to disconnect everything and UNPLUG everything EXCEPT your amp, plug it straight into the wall, and fire it up. Do you still hear noise? If you do, does grabbing any metal part of the amp (chassis, screws, etc.) cause the hum to change any? Once you've done that, move the amp to the far side of the house and try again. Same noise? Same intensity? Finally, put your amp back and start reconnecting components one at a time, moving from the "closest to the amp" in the chain further and further out until you find the one introducing the noise (assuming it's not coming from the mains).Was wondering if anyone could help me out here. When I turn the volume knob past the 4th dot a hum can be heard and gets louder in my headphones as the volume increases and I was wondering if this is normal. It happens to my Aeolus(with all the cables I have for it too) but not Edition XS so I was wondering if maybe it's an impedance thing since they have very different values. This is with no sound playing and happens with stock tubes as well as new the tubes I switched in. This is my first tube amp and I heard that it's normal for some to not be dead silent.
