FIIO Q15 DAC and Headphone Amplifier Discussion & Impressions Thread
Nov 7, 2023 at 3:05 AM Post #2 of 781
After 4 years, the upgraded model of the Q5S, the Q15, is finally coming out.
We first use AG glass for the Q15’s back panel, which is anti-scratch and anti-fingerprint with a delicate touch. Coupling with the golden size ratio of 18:9 makes it comfortable to use both when being handheld and when bundled with other portable devices.
The Q15 is not only easy to hold, but also features desktop-grade technical features and strong performance.
The Q15 features a new desktop mode, sporting a separate Type-C power connector for it. When the Q15 is connected to the PD power adapter, the Q15 will be powered externally completely bypassing the battery, allowing for a desktop-like experience even on the go. When put in Desktop Mode, the Q15 under balanced output is capable of putting out 1600MW in enhanced over-ear headphone mode, which is more than enough to easily drive various IEMs and full-size headphones.
There are 3 days left before the DAC and Headphone Amplifier Q15 comes out. Let's stay tuned!
Nov 7, 2023 at 11:53 AM Post #3 of 781
It will be interesting to see how this compares to the Q7, given that it kind of looks like a mini-Q7. Will it effectively be a Q7 without DC power and an "Ultra Gain" mode?
Nov 8, 2023 at 1:56 AM Post #4 of 781
The Q15 is the only model among products of the same grade that features AKM’s newest DAC combination - the AK4191EQ+AK4499EX. When working in tandem with the newly developed “DWA Routing Technology”, audio performance is greatly improved. The result is a more detailed, yet natural and realistic sound that makes the listener think they have been transported to the concert site.
There are 2 days left before the DAC and Headphone Amplifier Q15 comes out. Let's stay tuned!
Nov 8, 2023 at 10:42 PM Post #5 of 781
The Q15 features triple hard cores - TI Cortex M4 processor, XMOS 16-core XU316 with audio and dual crystal oscillators, and Qualcomm QCC5125 Bluetooth chip, combing USB DAC, Bluetooth and coaxial decoding in one.
USB DAC supports 768kHz/32bit PCM, DSD512 and MQA full decoding; Bluetooth decoding supports hi-res Bluetooth codecs like LDAC and aptX Adaptive; coaxial decoding supports 92kHz/24bit and DSD64.
There is 1 day left before the DAC and Headphone Amplifier Q15 comes out. Let's stay tuned!
Nov 10, 2023 at 3:33 AM Post #10 of 781
Portable Desktop-Grade Machine! DAC and Headphone Amplifier FIIO Q15 Is Officially Released!​
After 4 years, the upgraded model of the Q5S, the Q15, is finally coming out. The Q15 brings together FIIO’s cutting-edge technologies and platforms in an easy-to-hold body, delivering a more comprehensive performance than any other product in its class, and is dedicated to fulfilling the rich needs of your portable or desktop use in a single device.
Portable desktop-grade machine
FIIO first uses AG glass for the back panel of the Q15, which is anti-scratch and anti-fingerprint with a delicate touch. Coupling with the golden size ratio of 18:9 makes it comfortable to use both when being handheld and when bundled with other portable devices. Whether you are simply on the go or on a business trip, you can easily remain in control of your high-quality sound.
As a portable desktop-grade machine, the Q15 features a new desktop mode, sporting a separate Type-C power connector for it. When the Q15 is connected to the PD power adapter, the Q15 will be powered externally completely bypassing the battery, allowing for a desktop-like experience even on the go. When put in Desktop Mode, the Q15 under balanced output is capable of putting out 1600MW in enhanced over-ear headphone mode, which is more than enough to easily drive various IEMs and full-size headphones.
AKM flagship DAC combo
Same configurations as a flagship
The Q15 features triple hard cores - TI Cortex M4 processor, XMOS 16-core XU316 with dual audio crystal oscillators, and Qualcomm QCC5125 Bluetooth chip, combing USB DAC, Bluetooth and coaxial decoding in one. USB DAC supports 768kHz/32bit PCM, DSD512 and MQA full decoding; Bluetooth decoding supports hi-res Bluetooth codecs like LDAC and aptX Adaptive; coaxial decoding supports 92kHz/24bit and DSD64.
Moreover, the Q15 features a 1.3-inch full-color IPS display, allowing a clear glance at the working mode, sampling rate, volume level, battery level, gain, etc. Combined with the versatile knob, you can quickly and accurately realize a variety of functions, such as volume adjusting input switching, and menu settings.
Independent phone mode switch, standard RCA coaxial connector, global PEQ, 5-level audio circuit, impressive internal components... There are more surprises waiting for you.
* The Q15 is available on our AliExpress Official Store. Any order will be included with a matched leatherette case and an LT-LT2 cable as gifts. Click the link below to take it home right away:
https://www.aliexpress.com/item/1005006220930258.html
Best regards,
Guangzhou FIIO Electronics Technology Co., Ltd.
Nov 10, 2023 at 6:36 AM Post #13 of 781
output power without "desktop mode": 340mW BAL and 85 for SE.
what amp tech is used?
And why Fiio do not used LHDC codec? LHDC much better than LDAC
