Ben86
- Jun 24, 2015
Dear friend,So what is the global price actually ?
By clicking Ali Ex link, the price displayed not the level of Shan H7 category…
Dear friend,I can't find any information about overall dimensions and weight anywhere.
Will there be an option to adjust the equalizer on ios?
Dear friend,How many gain levels it has? As I understand 1600mW power output can be reached only with DC power? What are the power output gain levels (mW) in battery mode???
L+R≥635mW+635mW (16Ω,THD+N<1%) |
L+R≥1610mW+1610mW (32Ω,THD+N<1%) |
L+R≥340mW+340mW (300Ω,THD+N<1%) |
On the one hand it may not seem like much, on the other hand if you use iems this will be enough, and need real test/review for this question I thought that there would be the same amplifier as in Q7. A very strange approach: a flagship chip and silence about the amplifier part.Whaaat??? Why is output power SO LOW???
Dear friend,output power without "desktop mode": 340mW BAL and 85 for SE.
what amp tech is used?
And why Fiio do not used LHDC codec? LHDC much better than LDAC
But...FW3 does support LHDC. Many smartphone support LHDC: BBK, Xiaomi.Dear friend,
Considering there are not too many devices which support LHDC and the LHDC support will bring some compatibility problem, we don't add the LHDC support for Q15.
Best regards
No one really uses coaxial. I think optical would have been the better option imhoDear friend,
Yes, if you would like to use optical in, you could consider our Q7, BR13, BTA30Pro, K7 instead.
Best regards
Optical is usually consider as having higher digital noise.No one really uses coaxial. I think optical would have been the better option imho
Quite possibly but I just think there are so many more devices using optical instead of coaxial. Televisions for example.Optical is usually consider as having higher digital noise.
Yes of course. But for sound quality alone I would choose coaxial.Quite possibly but I just think there are so many more devices using optical instead of coaxial. Televisions for example.
Hi, Friend,On the one hand it may not seem like much, on the other hand if you use iems this will be enough, and need real test/review for this question I thought that there would be the same amplifier as in Q7. A very strange approach: a flagship chip and silence about the amplifier part.
Hi dear!Hi, Friend,
As the Q15's project manager,
I think we need to think more about the all of the product, as well as heat generation and overall power consumption
We think the output power is sufficient.
Of course the Q15 is positioned, below the Q7. because the Q7 is bigger, so he can have the big battery and make the power bigger.
The Q15 is more portable, and he has a definite advantage in terms of size and heat generation.
in fact, 1600mW is enough
