FIIO Q15 DAC and Headphone Amplifier Discussion & Impressions Thread
Apr 25, 2024 at 4:07 PM Post #736 of 779
Happy to be able to help... when you launch the tool could you tell me what firmware is installed before the update?
Yes, it was the 1.66 version, but have updated it now.
Apr 25, 2024 at 6:19 PM Post #737 of 779
How is the experience of using the Q15 on the latest firmware? I've seen some mixed messages on whether most of the issues are fixed now or not, and it's not confidence inspiring to see people having bricked units after updating to the latest firmware. I'm trying to decide between it and the Shanling H5 which has its own issues with Bluetooth connectivity but it seems more like a finished product than the Q15. I know it's missing some features such as PEQ and doesn't have a way to bypass the battery but I've also experience first hand how frustrating Fiio's app can be. Any thoughts and experiences would be greatly appreciated!
Apr 25, 2024 at 6:31 PM Post #738 of 779
From what I understand, the biggest problems that the Q15 has are precisely inherent to the use of the PEQ which is what is not present in the H5 and which I therefore assume interests you. I bought it precisely because I wasn't interested in this function (which for now still seems to present problems) and to compare it with the H7 that I own and am very happy with. If the Q15 offers a sound similar to the H7 I will be satisfied also because the lack that I consider most important in the H7 is precisely related to the lack of a Desktop Mode type solution proposed by FiiO, so when the H7 needs to be recharged I will have the FiiO ready to play. Having said that, I hope not to suffer bricks during the update, even if this thing (according to FiiO) should have been overcome with the new batches of the product. Fingers crossed.
Apr 25, 2024 at 7:22 PM Post #739 of 779
That's what I was seeing as well, as much as it's a headline feature of this DAC/amp if it doesn't work well I'd rather not have (and pay for) it at all. You would think Fiio could have a functional EQ by now but I had similar issues with my BTR5 so it's not great to see they're still struggling with the same problems several years later. I know it won't be as good as hardware-level PEQ but if I need to tame the vocals of an earbud I can always use Poweramp EQ with the H5. The same goes for the Q15 but it would feel worse knowing I could be doing it in hardware instead.
It's frustrating that Shanling didn't consider this a priority (and still doesn't based on their comments about the design of the H5). And while you can have one of their dealers replace the battery they've also admitted that they only keep so many on hand after a product is no longer being made. So either way your device has a limited shelf life which isn't great but at least I know that up front. It's also not comforting that Shanling doesn't recommend you use and charge the H5 at the same time which really makes me question the quality of the battery they used.
It seems like Fiio's great hardware is always let down by unfinished firmware and buggy apps, at this point I doubt they'll ever change so it's just something you have to accept if you buy their products. I probably would have bought the Q15 until I saw the reports of bricked units, that's a big red flag as I'm not confident that Fiio's support would replace any bricked units. Hopefully your experience with the Q15 goes well, any additional experiences regardless of outcome are appreciated.
Apr 26, 2024 at 6:42 PM Post #740 of 779
I understand your point but I wonder, if you think PEQ is your priority why haven't you thought about purchasing a Chord Mojo2? From what I've read it has one of the best PEQ implementations around, although a little peculiar in its use. I repeat, I am not interested in any type of equalization, neither software nor hardware because I think that every DAC and every IEM must sound the way it was designed to do so and I just enjoy finding synergies between the sources and the IEMs. /headphones. Shanling probably thinks like me and wants to propose her "her" sound and doesn't want it to be modified and honestly I really like the way they implement their DACs. As far as batteries are concerned, there are serious companies like Shanling that tell you that it is possible to charge the battery while you listen but this will inevitably reduce the charging cycles and others that instead tell you to do as you want without worrying. It's not a question of battery quality but of serious companies that tell you what to do to make the best use of their products and others that instead play on words... no battery likes to be recharged on one side while being simultaneously discharged on the other . This applies to all batteries... even those fitted by manufacturers who tell you not to worry... certainly nothing happens to the battery if you do it once (playing on words) but if this practice is repeated cyclically it certainly doesn't it's good for you and this also happens in cell phones. In fact, FiiO has created the Desktop Mode function which avoids having to charge a battery indefinitely while the Q15 is connected to the computer... just remember that it would be better to use this function when the battery is between 20% and 80% and more precisely around 50%. Having said that, I chose the H7 mainly for the fact that it features two standard 18650 batteries that are easily available and replaceable, unlike those of the H5.
Apr 27, 2024 at 2:03 PM Post #742 of 779
Hello fellow Q15 users, does the PEQ work in USB as of the current firmware update? Also how does it compare to the Gryphon in terms of sound and overall quality?
The PEQ does work in USB mode, but you have to switch MQA off to enable it and, in my experience, you can't be connected to your source when you do. When mine was connected to my iPhone and I made the switch, it confused the iPhone and I had to remove and then connect it again. When I unplugged first and then plugged back in, it worked.
I can't say how it compares to the Gryphon, but I'm finding the sound quality to be excellent with my Dan Clark Audio Aeon 2 Noire. There's a ton of power, so I can drive them in both the 3.5mm single-ended and the 4.4mm balanced. There's a lot of headroom in both, but obviously more in balanced. I like the sound so much that I haven't even messed with PEQ, but I'll probably mess around with it a bit to eek out that last bit of quality.
Apr 27, 2024 at 5:39 PM Post #743 of 779
Which low pass filter do you use the most and why? Thank you.
Apr 28, 2024 at 1:24 AM Post #744 of 779
A lot of folks definitely see it the way you do! I used to, as well, but after a while I realized (a) no product is perfect for any of us (and we all want something different) and (b) I paid for the gear and if I can easily adjust it in some way (like EQ) that maximizes my enjoyment, I certainly will.
Apr 28, 2024 at 4:16 AM Post #745 of 779
I agree with you but from what I understand FiiO has had a PEQ problem since the release of the BTR5 (two years ago now) which it has not yet resolved. In addition to this, you are right in saying that something you paid for must work, but then it is even more serious if its malfunction affects the entire device (automatic activation when switching from Bluetooth to USB and consequent loss of volume). I honestly wanted to buy the Q15 with the hope that it will have a sound close to the H7 (which costs more than twice as much) and I sincerely hope that these problems with the PEQ are solved, so everyone will be happy both the users, who use it (like you ) than those who don't use it (like me).
Apr 28, 2024 at 12:48 PM Post #746 of 779
I agree that the Mojo2 has amazing EQ but it's in a completely different price bracket and doesn't have built-in Bluetooth which as much as it pains me to say it I prefer for mobile use over dealing with a dongle DAC plugged into my phone. I know there's a Bluetooth module available but it adds even more cost to an already expensive product, especially one for mobile use. If I damage either the H5 or the Q15 during mobile use it's not the end of the world, though I wouldn't be happy, but if I damaged or lost the Mojo2 it's a completely different story especially if I also had the Bluetooth module.
I completely understand your views on EQ, my issue is that I can't use IEMs due to ear issues so I'm limited to flathead earbuds which are a very niche product category. With how few options there are compared to IEMS having some form of EQ is almost mandatory to correct any small issues I have with a particular earbud, as I can't as easily find one that sounds exactly how I want. And while it may seem like overkill to use either for earbuds, there are some that have ridiculously low sensitivity and very high impedence such as the Yinman 600 that I would like to try but need a capable source to properly drive them. But I do agree that matching an earbud to a source is a good idea, I've run into that with one of the earbuds I got recently where it sounds great on one source but sounds harsh and sibilant on others.
That's a good point about the battery, and their honesty and frankness about design decisions for the H5 is what made me ultimately go with it. At least they're thinking ahead to when customers have dead or dying batteries which I don't think a lot of other companies go that far. And while the H7 has an easier to source battery from what I've read I'm not convinced that its sound quality is worth almost double the price as the H5 seems to be very close. I also don't know how much I would make use of the Q15's desktop mode right now, I was only thinking of using it when the battery wears out but I would probably want to either replace the battery or get another portable source anyway. The warmer sound of the H5 was the deal breaker as I was afraid that the Q15 might be slightly too bright for some of my buds especially if I couldn't rely on its EQ.
If Fiio ever fixes all of the firmware issues the Q15 has then I'll give it a second look but for now I think I made the right decision. Thanks for your thoughts and insights!
Apr 28, 2024 at 2:11 PM Post #748 of 779
Except correct me if I'm wrong, but the Q15 no longer has issues with PEQ or major issues with the firmware. Yes, you have to turn MQA off to enable PEQ, but I'm not sure if that's actually an "issue."
I think that the MQA setting is essentially acting as a “bit perfect” setting, which logically would disallow any sort of EQ, because MQA requires bit perfect. What I think would be a friendlier implementation would be to allow both MQA and PEQ to be enabled and if the Q15 detects an incoming MQA stream it automatically disables PEQ, and enables it when no incoming MQA stream is detected (making the MQA setting a “bit perfect when necessary” setting). That and maybe rename the MQA setting to “bit perfect”.
Apr 28, 2024 at 3:48 PM Post #749 of 779
Sure, that makes sense. But then, it would appear that PEQ is indeed working with the latest firmware.
May 1, 2024 at 5:09 PM Post #750 of 779
For some reason the power usage of my q15 has increased drastically even though i haven't changed anything. It was drawing 3-4w in desktop mode and around 1w in idle/power off (which is very high i think), now it draws 6w in desktop mode and 3w in idle/power off mode and it stays hot even when it is not used now. Any idea why did this happen?
